Big brake kit. VC vs.GW...
GreggK
GreggK is offline
PostPosted: Sat Apr 01, 2017 7:26 am    Post subject: Big brake kit. VC vs.GW... Reply with quote
Hello All,
Can anyone give a fair comparison of the Go Westy bigger brake kit vs. the South African Big brake kit. I was set on the GW kit but then the SA kit came back with Volks Café. Is it wise to upgrade the brake booster with either of these kits?
I'll be doing the install on a 2wd. I'll probally leave the rear brakes as drums, just re-build them. Any opinions?
Thanks GreggK
jimf909
jimf909 is offline
PostPosted: Sat Apr 01, 2017 10:03 am    Post subject: Re: Big brake kit. VC vs.GW... Reply with quote
There are quite a few threads on this although beware of years-old posts that may have outdated info because kits have changed.
https://www.thesamba.com/vw/search.php?q=Big%20brakes%20vanagon
After reading a bunch I'm going with the GW kit because a) my tech prefers it b) the differences between kits are too small for me to worry about and c) I need to replace many of the parts anyway so I'm choosing to go with bigger brakes.
Idaho Doug makes compelling arguments that stock is best. In the end we'll all choose the best option for our own situation.
- Jim
Butcher wrote:
Guilty as charged.
WestyBob
WestyBob is offline
PostPosted: Sat Apr 01, 2017 11:49 pm    Post subject: Re: Big brake kit. VC vs.GW... Reply with quote
I have done two with the VC kit and have been very happy.
Also check out SmallCar's kit.
Frankly I don't think you could go wrong with any of the three as long as the install is tight.
Team WorldTour
Team WorldTour is offline
PostPosted: Sun Apr 02, 2017 1:31 am    Post subject: Re: Big brake kit. VC vs.GW... Reply with quote
I too have done the BBK from Gowesty AND VC.
I'm not sure which one was which, but I have had them on both of my vans, and I'm glad I did!
First set, Stock Brake Booster, H6 converted Westy. Could happily cruise the German Autobahn at 220kph, could also come to a screeching halt at a moment's notice with enough force to throw everything against the front seats! Shocked (I say screeching halt, but never actually locked up the wheels!)
Second van, kinda weird, has both the BBK AND the Booster upgrade. It is a Syncro tin-top (at the moment), and though I have a soft pedal, the resulting braking force is anything but.......this too has the braking force to throw everything forward without locking up the front tires.
(Not to imply that I regularly need this, but to illustrate for test purposes...)
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
davevickery
davevickery is offline
PostPosted: Sun Apr 02, 2017 4:46 pm    Post subject: Re: Big brake kit. VC vs.GW... Reply with quote
If you can get a VW designed part vs. a small aftermarket maker, that's how I would go. It isn't rocket surgery to come up with brake parts that work, but there are things that aren't perfect about them. With VW SA I am assuming you're getting more thought and experience going into the choice of parts/design.
