flameisley Samba Member
Posted: Mon Oct 23, 2017 10:29 am Post subject: auto transmission fluid |
| I have a transmission leak so I checked the fluid levels and it's just a bit below low. Is this transmission fluid okay to top it off? I did some research but could not find a straight answer. Also, how much should I put? Half a quart, the whole bottle? I'm a newb so I really have no idea. |
Posted: Mon Oct 23, 2017 11:44 am Post subject: Re: auto transmission fluid |
| It is fine. Do check the level of the gear oil in your final drive, if the level is high and/or it appears there is ATF mixed with the gear oil, you may have a leak between the two boxes which needs to be fixed ASAP. |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Mon Oct 23, 2017 12:53 pm Post subject: Re: auto transmission fluid |
| flameisley wrote: |
It really does not take much ATF to jump from the MIN mark to the MAX mark..so proceed with care. Over-filling is not good.
Be sure you are checking the AFT level by the book..engine/transmission warmed up and engine idling..on level ground..in PARK. The ATF level should be between the MIN and MAX marks on the dip-stick.
I very much like the MaxLife ATF..very good stuff. It stinks to high heaven though..don't spill any if you can.
Once you are comfortable with checking your ATF..plan on servicing the transmission (if you don't know when the transmission was last serviced) with a new filter and pan gasket and a refill of the nice MaxLife ATF too. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Mon Oct 23, 2017 12:57 pm Post subject: Re: auto transmission fluid |
I'll quote member kourt from an earlier thread.......
| kourt wrote: |
I agree. If you had no ATF in the automatic transmission and you idled a cold engine for two minutes but did not actually drive, you probably have nothing to worry about.
Make sure you fill and check the transmission level properly, as most people get it wrong:
1. hot engine (driven 10 miles)
2. parked on level surface
3. engine idling while checking ATF
4. level should be between two dots on dipstick
kourt |
As a guide to cold ATF level, here a an older post of mine......
| djkeev wrote: |
It isn't always convenient to check the Automatic Transmission Fluid level once underway.
We all know you should drive a bout 10 miles, park level, yada yada yada........
On a trip this means unloading everything above the engine access lid.
I had a bad leak for years and have checked the oil level a LOT!!!!
It is fixed now but I wondered what is the level on the dipstick when cold?
Temperature 38°, engine not yet started after sitting all night........
I'm thinking of filing a notch on the stick as a cold full mark.
Sure, verify proper level when hot as I did the night before I took these photos cold, but what a great way to gauge your level on the morning pre-flight engine check.
Dave |
_________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Mon Oct 23, 2017 2:07 pm Post subject: Re: auto transmission fluid |
| Great info! Thank you everyone. |
Vantropy Samba Member
Joined: November 22, 2019 Posts: 78 Location: Oakland, CA
Posted: Tue May 12, 2020 10:05 am Post subject: Re: auto transmission fluid |
Just added a Small Car auto trans cooler.
Before the install, I measured the ATF (operating temp, idling, level) and it was high.
Only lost about 3-4oz of ATF in the cooler process, so thought it might bring it down where it should be. Drove for 5 minutes, found things weren’t tight enough & were leaking. Got back, checked ATF (operating temp, idling, level) and it was quite low, just at the tip of the dipstick. Added about 6oz of ATF. Called it a night.
Next day, I check the dipstick cold after settling, looking for it to be near the tip of the dipstick again. Instead, it’s overfull. I’m wondering if after filling, the engine needs to be idled a minute to settle the ATF? Or did I just add too much? _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
SCM Samba Member
Joined: January 26, 2011 Posts: 3483 Location: Bozeman MT
Posted: Tue May 12, 2020 10:09 am Post subject: Re: auto transmission fluid |
I'm convinced that measuring the ATF is a mysterious black art sort of thing.
Mine always appears too high, even after I got it back from being rebuilt and installed by a pro. It seems to work fine so I just monitor it to make sure the level hasn't changed.
Question: if you haven't driven the van far enough to be adequately warm, would you expect the ATF level to read higher or lower than it would if you drove the correct number of miles prior to measuring? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue May 12, 2020 10:31 am Post subject: Re: auto transmission fluid |
| SCM wrote: |
Question: if you haven't driven the van far enough to be adequately warm, would you expect the ATF level to read higher or lower than it would if you drove the correct number of miles prior to measuring? |
Lower. Per Bentley, at 20deg C(68F), fluid should be just at the crosshatched tip of the dipstick. At operating temperature, between two marks. I'm assuming the ATF expands as it warms. That's why I'm confused that it went from barely touching dipstick hot to overfull cold the next day with just 6oz of ATF.
Dave quotes Kourt here that the van should be driven 10 miles. Perhaps this is the problem: I only drove 1.5 miles. The engine was at normal operating temperature, but perhaps the transmission wasn't? I must admit, that I don't like the idea of 10 mile drives on a transmission that I'm not sure is properly filled! _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
Posted: Tue May 12, 2020 11:44 am Post subject: Re: auto transmission fluid |
| The reason you check the ATF hot and running is that that is the standard. Checking it cold and/or not running is pretty meaningless especially if your system is no longer stock, as per yours with an added cooler. |
Posted: Tue May 12, 2020 1:21 pm Post subject: Re: auto transmission fluid |
| Wildthings wrote: |
It seems fairly useful to be able to get the level close before you go around driving the thing up to full temperature. Which is probably why the Bentley has instructions for a cold level check. Sure, if you’re replacing all the fluid, you add your two quarts and you’re in the ballpark. But what if you have a leak and don’t know how much you have in there? Do you just idle it up to operating temp and not engage the transmission in order to check?
As for the cooler, it uses the same ports as the stock cooler, and once full, I can’t see how that would affect the level, which should still be the same regardless.
*Edit: now that I’m draining some fluid back out, I could see how it’s possible that some of the trans cooler’s extra capacity flows back into the trans, giving a false high cold reading (as you’re saying Wildthings, making the cold reading useless). Does anybody else with an add-on cooler have that problem? _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
Posted: Thu May 14, 2020 10:20 pm Post subject: Re: auto transmission fluid |
kourt's advice above to check fluid after driving 10 miles is worth noting. Everywhere I see that this test should be done "at operating temperature," and you might think that this is when the engine gets up to operating temperature.
But the truth is that the transmission takes longer to warm up than the engine. Like: twice as long. Once I got my gauge hooked up, I kept thinking I had a problem, that the gauge wasn't working. But I had only been driving a couple miles and it hadn't even registered past 100 degrees. After ten minutes of driving, it's up to a stable 150 degrees.
And at that point, I take get my ATF measurement correctly.
And yes, when the engine cools down, the dipstick reads high still. So I can conclude that after adding a transmission cooler, there will be a higher cold reading than stock. I'm guessing this is due to the volume of fluid that is in the hoses above the fittings draining down into the pan. _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Fri May 15, 2020 7:06 am Post subject: Re: auto transmission fluid |
| Most of the heat developed in an automatic transmission is from the torque converter. It's really not working while in park. That is why you need to drive the vehicle for several miles. Freeway driving seems to be the fastest. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19160 Location: Retired South Florida
Posted: Fri May 15, 2020 8:33 am Post subject: Re: auto transmission fluid |
| You don't want the fluid draining out of the hoses. That means everytime you start the engine, the air will need to be purged from the system before you reach system pressure. I would confirm that is what is happening. |
Posted: Fri May 15, 2020 9:14 am Post subject: Re: auto transmission fluid |
| MarkWard wrote: |
I'm not sure how I could confirm this, but I'm also at a loss to explain how otherwise the cold ATF level is higher than the hot. I'm not too worried about it, since this method of attaching an external transmission cooler has thousands of successful installs and millions of miles of use. If they were destroying transmissions, we'd probably know about it by now. _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10163 Location: Abiquiu, NM, USA
Posted: Fri May 15, 2020 10:51 am Post subject: Re: auto transmission fluid |
After sitting awhile and starting cold, you have to put the auto-trans briefly into every gear for a couple seconds while holding the brake, then put it in Park and only then can you expect an accurate fluid level reading. Fluid in the valve body and control passages will drain down over time and raise the fluid level, a lot. Running the engine and putting it briefly into each gear fills all the internals of the trans and it is only in that condition, plus the fluid being at operating temp, where you can get an accurate level reading. There's a pretty narrow range of volume allowed, overfilling will damage the trans as well as running low, so auto-trans fluid checking is considerably more stringent than an engine or manual trans. Observe the steps specified on the Bentley page copied above, follow every one.
Your external oil cooler will also be filled by doing this, just as the stock one would, making the question as to whether or not it also drains down moot.
Checking level without the engine running tells you nothing of value, except that there is some oil in the thing. Any time you check level on a cold auto-trans that has been sitting for hours, you should expect it to read well above the Max mark before the engine is started, then after starting and putting it in each gear, then in Park, if filled correctly it should read at about the cold or Min mark, then at operating temp it should read at the Max mark. The last one is the one that matters.
And yes, warming the engine up without driving won't warm up the trans, it has to be driven for some time, the page above states 6mi. (10km). _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Please don't PM here, I will not reply. |
Posted: Fri May 15, 2020 12:01 pm Post subject: Re: auto transmission fluid |
| tencentlife wrote: |
| Any time you check level on a cold auto-trans that has been sitting for hours, you should expect it to read well above the Max mark |
Then why does the Bentley (37.9) state: "when cold, fill to 20deg C mark" [tip of dipstick] ?
I get that this isn't the final and authoritative measurement, but from reading the Bentley it seems as though a cold trans should read less ATF than a hot one. _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
jlrftype7 Samba Member
Posted: Fri May 15, 2020 2:01 pm Post subject: Re: auto transmission fluid |
| Vantropy wrote: |
| MarkWard wrote: |
I'm not sure how I could confirm this, but I'm also at a loss to explain how otherwise the cold ATF level is higher than the hot. I'm not too worried about it, since this method of attaching an external transmission cooler has thousands of successful installs and millions of miles of use. If they were destroying transmissions, we'd probably know about it by now. |
It's possible that your TC is draining back, and that raises the Cold level of the fluid until you've run the trans/engine to refill the TC. BUT, if you were to engage your transmission into a gear AND that drain back had occurred , you'd normally have a delay getting movement with any transmission as the Torque Converter was still filling up. Have you experienced that symptom at all with a first start overnight? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri May 15, 2020 2:40 pm Post subject: Re: auto transmission fluid |
| Vantropy wrote: |
I get that this isn't the final and authoritative measurement, but from reading the Bentley it seems as though a cold trans should read less ATF than a hot one. |
The engine needs to be running to check the level, whether hot or cold. |
Posted: Fri May 15, 2020 4:00 pm Post subject: Re: auto transmission fluid |
| Wildthings wrote: |
Whoa. This just blew my mind. It never dawned on me that when they said "cold," they meant "cold with the engine running."
Which is exactly what tencentlife said but I missed:
| After sitting awhile and starting cold, you have to put the auto-trans briefly into every gear for a couple seconds while holding the brake, then put it in Park and only then can you expect an accurate fluid level reading. |
In the Bentley, these instructions are at the top of the page, and then they apply for all the tests afterward hot or cold.
Guess what? I started the engine, put it through all the gears and measured the ATF: right down there at the tip of the dipstick like it says it should be!
Thanks Wildthings & Tencentlife! _________________ 1989 2.1L Vanagon Westy, Automatic, Titian Red |
