Couple pictures of Digifant ECU - my hunting idle culprit
n2wheelies
n2wheelies is offline
PostPosted: Tue Dec 12, 2017 11:30 am    Post subject: Couple pictures of Digifant ECU - my hunting idle culprit Reply with quote
hello, been fighting a hunting idle and part throttle oscillation like throttle snatch for EVER, its found, my buddy loaned me an ECU. I have tried everything else. a few photos of found cold solder joiint, not sure if this resister is suspect, going to fix the solder joints first and try it out
'87 Vanagon Weekender 'ELNINYO'
past vw's...
'09 Jetta Sportwagen 'Pearl'
'60 Deluxe Beetle
'09 EOS 'petal'
'78 scirocco
'66 T2 panel dead tour vehicle, 'mr bus'
'67 13 window
'95 eurocamper 'charlie' (phish tour vehicle)
'03 Mk4 TDI 'steve'
'04 W8 Phaeton 'david'
DanHoug
DanHoug is offline
PostPosted: Tue Dec 12, 2017 11:44 am    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
classic. the resistor should still be good. i'd measure the value, order one of a higher wattage that will still fit, and then solder it back in the standoffs but with longer leads so the resistor heat can dissapate a bit before hitting the PCB. won't take much length. that PCB can be cleaned up after the posts are removed.
you can 'rebuild' the entire ECU by attacking that resistor, shot gunning all the electrolytic caps, and reflowing each solder joint.
a tool like this is incredibly wonderful for desoldering components:
https://www.hakko.com/english/products/hakko_fr300.html
-dan
n2wheelies
PostPosted: Tue Dec 12, 2017 12:54 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
resoldered the suspect connections, no change Sad
past vw's...
'60 Deluxe Beetle
'09 EOS 'petal'
'78 scirocco
'67 13 window
'03 Mk4 TDI 'steve'
DanHoug
DanHoug is offline
PostPosted: Tue Dec 12, 2017 2:37 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
the capacitor next to the resistor is also bad... electrolyte oozing out from under the top cap. it is next to the very hot resistor so that makes sense that it has failed too.
were it mine, i'd replace ALL electrolytic caps. source them from Digikey.
-dan
DanHoug
DanHoug is offline
PostPosted: Tue Dec 12, 2017 2:40 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
-dan
djkeev
djkeev is offline
PostPosted: Tue Dec 12, 2017 3:03 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
Yeah........
I'm not even going to try to fix mine that exhibits a miss....... anyone want it to play with?? Free, pay shipping.
Edit: ECU found a home.........
Dave
Ghia
Vanagon
Beetle
n2wheelies
PostPosted: Tue Dec 12, 2017 3:30 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
ive already gone the go westy route... thanks for the reply. i may try to fix it in the meantime as I have a loaner ecu. how do I determine the resistance of that suspect resistor since you said 'too'?
past vw's...
'60 Deluxe Beetle
'09 EOS 'petal'
'78 scirocco
'67 13 window
'03 Mk4 TDI 'steve'
DanHoug
DanHoug is offline
PostPosted: Tue Dec 12, 2017 6:24 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
my 'too' failure reference regarded the PCB/solder melt at the resistor. but since the markings are burned off the resistor, it should be swapped out. you'll have to unhook one end and then measure the resistance with an ohm meter. no way to check it in circuit.
-dan
n2wheelies
PostPosted: Thu Dec 21, 2017 12:21 pm    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
go westy unit arrived. ran fine around town, but fails after 30 minutes of freeway driving. hope they have the resources to 'test' that on return, having a tech drive 60 miles to 'confirm' its faulty.
past vw's...
'60 Deluxe Beetle
'09 EOS 'petal'
'78 scirocco
'67 13 window
'03 Mk4 TDI 'steve'
fortheloveofvdub
fortheloveofvdub is offline
PostPosted: Thu Apr 19, 2018 9:30 am    Post subject: Re: couple picture of digifant - the ECU was my hunting idle culprit Reply with quote
What were your symptoms please?
