rear brake drums
web macomber
web macomber is offline
PostPosted: Fri Dec 15, 2017 9:34 am    Post subject: rear brake drums Reply with quote
Hello. I have been cleaning and replacing some of the hardware on the rear brakes of 73 beetle. Everything is fine but while doing one side I noticed that I may have put the connecting rod that goes between the shoes upside down.
Does the concave part go up or down? Anyway it seemed to make more sense with it going up but when I tried to get the drum back on, I could not. Shore are straight, star wheels all the way in but the drum will just not go on. I did fine before? Any clues?
Web in Wisconsin
alex857
alex857 is offline
PostPosted: Fri Dec 15, 2017 10:21 am    Post subject: Re: rear brake drums Reply with quote
Hi,
recheck: I think it only fits in one position! Because there is only one type of rod, the concave part is up on one side and down on the other. It Sound like you mounted it wrong, the brake shoes are too far apart now and that is why you can´t get the drum back on.
57BLITZ
57BLITZ is offline
PostPosted: Fri Dec 15, 2017 10:25 am    Post subject: Re: rear brake drums Reply with quote
The parking brake "connecting bar" is a one-size- fits right OR left side . . . thanks VW Rolling Eyes
https://www.thesamba.com/vw/forum/viewtopic.php?t=464562&highlight=parking+brake
It looks correct on one side while the other side "looks up-side-down" ! Wink
Jesucristo es mi Señor y Salvador!
web macomber
PostPosted: Fri Dec 15, 2017 2:36 pm    Post subject: Re: rear brake drums Reply with quote
ok, I will check for that. Thank you
volksworld
volksworld is offline
PostPosted: Fri Dec 15, 2017 4:42 pm    Post subject: Re: rear brake drums Reply with quote
the slots on the adjusters are cut on an angle to match the end of the shoe...deeper part of the slot on top
web macomber
PostPosted: Sat Dec 16, 2017 8:23 am    Post subject: Re: rear brake drums Reply with quote
good call on the adjusters. Who knew?? I must have just been lucky all of these years. Thanks again
Cusser
Cusser is offline
PostPosted: Sat Dec 16, 2017 9:29 am    Post subject: Re: rear brake drums Reply with quote
Who knew? Most of us who have had the same issue or at least discovered this many years ago.
Like the weird thing about the same spacer bar being used on both sides, when one side should've been made as a mirror image. Oh well.
By the way, the title of this thread should be "rear drum brakes" because "rear brake drums" is different !!
andk5591
andk5591 is offline
PostPosted: Sat Dec 16, 2017 10:01 am    Post subject: Re: rear brake drums Reply with quote
I can't even remember the number I times I have helped people with this same problem, nor the number of cars that I have worked on that had them in upside down or a mix of the early (straight) and late adjusters on a wheel. Shocked
Its not obvious, so don't feel like a dummy. Pretty much guarantee that most of us have done this at least once.....
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
ashman40
ashman40 is offline
PostPosted: Sat Dec 16, 2017 10:39 am    Post subject: Re: rear brake drums Reply with quote
Found some pics that illustrate the points made for anyone who stumbles across this thread in the future...
Here is a pic of the left rear drum brake assembly (front of car is to the left).
Note that the #6 bracket at the top of the shoes fits around both the rear shoe and the hand brake lever arm. The slot in the bracket is larger on one side to support the lever. This wider slot needs to be towards the rear of the car.
Here are pics showing the left and right side bracket and springs. Note that the wider slot is always towards the rear of the car because this is where the hand brake lever sits:
The biggest common mistake is thinking that the "groove" in the bracket is to make room for the spring. This is incorrect. The groove is there to stiffen the bracket and prevent it from flexing/bending. One bracket part# is used for both the left and right sides. The spring can either sit IN the groove or ON the hump of the groove, depending on which side the bracket is used.
AshMan40
