etrain Samba Member
Posted: Sun May 13, 2018 11:07 am Post subject: Clutch wing nut backing off |
On my 67 beetle, I seem to have to tighten the wing nut on the clutch every weekend to get it to shift nicely. A 1/4 turn does it nicely on Sunday, but by Wednesday, shifting is difficult again. There is plenty of thread left and it appears the wing nut backs off spontaneously. Has anyone seen this issue before or is my imagination working overtime? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11135 Location: Oregon
Posted: Sun May 13, 2018 11:31 am Post subject: Re: Clutch wing nut backing off |
Are you putting a pair of vicegrips in the metal sleeve of the threaded portion of the cable when adjusting the wing nut?
If not. Likely what's happening is that the cable is getting wound up when your adjusting the wing nut. Then as the week progresses. The cable unwinds, causing the clutch to go out of adjustment.
FWIW. I think I adjusted my clutch cable on my 67 2 times in the three years I have owned it.
Just sayin!
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33107 Location: Hot Arizona
EVfun  Samba Member
Posted: Sun May 13, 2018 12:03 pm Post subject: Re: Clutch wing nut backing off |
Or perhaps someone put an older clutch release arm on the transaxle. The older cars used a nut and a jam nut to hold adjustment. The seat was a round shape for the angular change. When the wingnut was introduced it had an oval shaped rounded seat and the clutch release arm had the same shape hole to keep the wingnut from backing off while allowing the needed angular change. _________________
Wildthings wrote: |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Sun May 13, 2018 1:28 pm Post subject: Re: Clutch wing nut backing off |
There are nubs and digits between the wing nut and operating arm, to keep it in place. If the nubs are worn, or if someone has put a washer there, that feature is lost.
Ditto on the vice grip hint. Also, grip the case sheathing, not the cable itself. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 13, 2018 4:13 pm Post subject: Re: Clutch wing nut backing off |
Are you adjusting the cable for exactly the proper amount of pedal play???
Which clutch arm does the rear of the cable pass thru?? Early has a round shape to it and later that uses the wing nut has a diamond shape. _________________ In Stereo, Where Available! |
