0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3456 Location: OR & CA (Oregon/California)
Posted: Fri Jun 15, 2018 9:04 am Post subject: Share your lucky story here... |
Please share your lucky story or discovery here for the benefit of all of us...
here's mine...
I was working on my son's 88 GL WBX 2.1 engine, fixing a broken connector on the power steering pump. Since the space is tight I moved the alternator a bit to the driver side to have more room for my hands... and I found this...
a closeup pic...
this is the fuel hose going from the T-connector to the #2 cylinder, behind and under the alternator. Last year on a trip the alternator died and was replaced by a shop 1K miles away from home. The bottom thin bolt on the alternator pinched and chaffed the fuel hose slowly and started a small fire... when? we don't know and not even smell the fuel leak... So I replaced the hose using one a bit longer and zip-tied it away from the alternator...
we guess that when they replaced the alternator they didn't move the hose far enough and let the thin bolt sit on the hose and the vibration did the rest.
so check that hose folks... and all other too...
all we can say that we were lucky...  |
shagginwagon83  Samba Member
Posted: Fri Jun 15, 2018 10:16 am Post subject: Re: Share your lucky story here... |
I feel like I was lucky to have an awesome grandma to give me an 83.5 Westy with 114k miles.
As far as working on the van - I felt lucky that none of my rear trailing arm bolts were seized. _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin
Instagram: @joannthevan |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17140 Location: Brookeville, MD
Posted: Fri Jun 15, 2018 10:44 am Post subject: Re: Share your lucky story here... |
dobryan wrote: |
Too many to count. But I'll put the 'ran myself over with my bus, all the way across my stomach from right to left' and had no serious injuries at the top.... |
There are better ways to workout your abs _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4549 Location: East Kootenay, British Columbia
Posted: Fri Jun 15, 2018 12:19 pm Post subject: Re: Share your lucky story here... |
Ours was coming back from a late fall/early winter trip to Chaco Canyon/Mesa Verde. Coming back we drove for a couple days through a bad winter storm, arriving home late at night.
The next morning I went out to move the Syncro into the garage and started the engine. Went inside for a few minutes to keep warm, came out to find all the oil on the ground.
Blew the oil seal at the oil cooler/block junction. This could have happened at some remote campsite. So lucky instead it waited to blow after we got home!
Later that day I ordered our Bostig kit. _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
E1 Samba Member
Joined: January 21, 2013 Posts: 8247 Location: Westfalia, Earth
Posted: Fri Jun 15, 2018 1:18 pm Post subject: Re: Share your lucky story here... |
I feel lucky that after a year of searching and finally giving up just 65 days from living on the road in a Jetta, I decided to look up a favorite link just for grins… and discovered the exact bus we were looking for just 12 miles away, even in the color we wanted.
Bought it the very next day. Lived in it for 59 months since. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 813 Location: Seattle
Posted: Fri Jun 15, 2018 1:45 pm Post subject: Re: Share your lucky story here... |
Picked up my Syncro from the guy that painted my van. I was driving through Seattle on hwy 99 in cold rainy weather when the motor started cutting out. It then died and I coasted to the shoulder. This was actually good because if I drove another mile further, I would have been stuck on the tight Aurora bridge or further down in the Battery street tunnel or on the waterfront viaduct where I would be really blocking during rush hour Seattle traffic. The business I ended up in front of was having a after hour customer appreciation night. I got to wait for the tow truck inside a warm building and partake in a buffet dinner. I think that would be considered lucky as opposed to freezing in my van waiting for the tow truck. |
