HenrikL Samba Member
Posted: Mon Oct 22, 2018 7:31 am Post subject: No fuse on wire to coil |
After changing the main wire harness I realize that the black wire from the dash to the ignition coil is not fused. This would mean that if I get a short-circuit I will fry the black wire and would have to replace the main harness again - including removing both front and read fenders.
Anyone know why this wire is not fused and why I should not add a fuse? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13960 Location: White Mountains Arizona
Posted: Mon Oct 22, 2018 7:33 am Post subject: Re: No fuse on wire to coil |
Ad the fuse. not sure why VW never fused that. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Mon Oct 22, 2018 9:21 am Post subject: Re: No fuse on wire to coil |
| VW never fused the ignition circuit on any Type. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5583 Location: Lefty, CA
KTPhil  Samba Member
Posted: Tue Oct 23, 2018 3:36 pm Post subject: Re: No fuse on wire to coil |
| While doing a tuneup, I had the main ignition wire start to burn when the accel pump arm pinched the wire to the choke/pilot jet. I heard and smelled it, and pulled it off just as the melting approached the coil. If it had happened while driving, my whole wiring bindle would probably be toast. A fuseholder, or circuit breaker might not be a bad idea... |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sat Oct 27, 2018 7:40 am Post subject: Re: No fuse on wire to coil |
I learned a very sad lesson about this. My fasty had the coil fall off the bracket while driving and kill the car. It smoked the entire harness, and I was on the freeway with my then one year old daughter. I had to replace it all with a harness from a junked car, and added a fuse to it. Now every one I begin to drive, gets a fuse for the coil.
No idea why they didn't, maybe an oversight? Maybe they didn't think it necessary? _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23602 Location: Kimball, Mi
Posted: Sat Oct 27, 2018 9:32 am Post subject: Re: No fuse on wire to coil |
| Sqrbckguy38 wrote: |
No idea why they didn't, maybe an oversight? Maybe they didn't think it necessary? |
What size fuse did you use? _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Sat Oct 27, 2018 10:48 pm Post subject: Re: No fuse on wire to coil |
I tried a 5amp but it would sometimes short out, so I used a 7.5amp and that seems to be the right one. It was in my fasty, my brothers sqr, and even now my 67 beetle. I just carry a spare in case, so it won't leave me stranded. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
67 Beetle, Opal |
Retrovan Samba Member
Joined: July 15, 2011 Posts: 541 Location: Port Elisabeth - RSA
Posted: Mon Oct 29, 2018 7:13 am Post subject: Re: No fuse on wire to coil |
The reason is that the uninformed, non mechanically minded guys do not get left standing because bad contact on the fuse.
We all know that these fuses need rolling from time to time to clean them or every thing stops working.
What I would do if you want protection, is fit a small circuit breaker in line that is under the dash.
This way you are sure to get to it when in a difficult situation and fit a 10 amp as this will trip, when faulty, but will not open circuit for fun.
OMO
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
