chisco_jfr Samba Member
Posted: Thu Nov 15, 2018 7:59 am Post subject: 1980 Vanagon Distributor Drive Gear Spacer |
Hi, I have a question about my VW Vanagon 1980 with 2.0L Aircooled Engine (CV). Can I use the "DISTRIBUTOR DRIVE GEAR SPACER" from T1 (part number: 111-105-235A) in a T4 engine? I can't find the T4 spacer in the web.
This is the spacer from T1
This is the spacer from T4
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10800 Location: the past
Posted: Thu Nov 15, 2018 9:46 am Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER |
No, you can not use the Type 1 washer. They are very dimensionally different from a Type 4 washer.
Type 1 on left, Type 4 on right.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18774 Location: Retired South Florida
Posted: Thu Nov 15, 2018 9:57 am Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER |
It's not exactly clear, but it looks like the part number is 021 105 235 for the 2.0 shim if that helps your search. I came across this link searching the part number. Porsche 914 probably used the same washer too.
https://www.thesamba.com/vw/forum/archive/index.php/o-t--t-178228--.html |
Posted: Thu Nov 15, 2018 10:13 am Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER |
hazetguy wrote: |
Did you know where I can buy the Type 4 washer? |
Posted: Thu Nov 15, 2018 10:59 am Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer |
Contact any vendor by phone, most have a shop or some association with a shop that might have bins full of misc. parts.
You could also place a WTB (want to buy) add in the Samba classifieds. |
Posted: Thu Nov 15, 2018 11:01 am Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER |
chisco_jfr wrote: |
i sent you a PM. check your inbox. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8412 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Nov 15, 2018 5:32 pm Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer |
I'm pretty sure I came across a member that was offering these in the classifieds recently...???
Have a look around...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Nov 16, 2018 6:14 am Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer |
Thanks to alll, specially to hazetguy. I found the washer here in the classifieds.  |
Posted: Fri Nov 16, 2018 7:45 am Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer |
^^^ Link? I couldn't find it...
"The WonderVan"
Posted: Fri Nov 16, 2018 8:01 am Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer |
Score! Glad you found one...
"The WonderVan"
