mauibarber Samba Member
Joined: January 30, 2009 Posts: 72 Location: Fort Collins, Colorado
Posted: Sun Jan 27, 2019 2:14 pm Post subject: I can't get my Bowden Tube off. What am I doing wrong. |
Trying to replace my Bowden tube. Does the bracket towards the rear of the car come off in any way? How do I get this thing off. The front of the bowden tube comes off no problem (the end towards the front of the car) but the rear that goes through that bracket is not coming loose?
66 bus.
Feel like a dummy but I can't get it off or see any kind of seperate bracket. It looks like the bracket is part of the transmission. _________________ -Alex |
Posted: Sun Jan 27, 2019 2:22 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
Does this bracket come off? took out 3 bolts and nothing comes loose. very greasy hard for me to see.
what is keeping the tube inside this bracket? _________________ -Alex |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 857 Location: clearwater,florida
Posted: Sun Jan 27, 2019 2:28 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
That bracket is part of the side cover and it does not come off like the later model Beetle ones do. I just did this job yesterday, I pulled the inner cable about 3 feet back and then I pulled it off from the other side and it fell right out. The Bowden tube is super stiff when bent in place, but it will move. Good news the side by the torsion only needs to pull back like 1/2 inch and it is off. The side shown in this picture would have to slide much further back.
Good Luck, you can do it.
TP _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 27, 2019 3:44 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
| mauibarber wrote: |
| what is keeping the tube inside this bracket? |
Hard to say from the blurry pic, but it looks like corrosion. Repeated application of PB blaster accompanied by heat and sideways (up/down) hammering should make it behave. Don't whack it hard inwards toward the trans, you might break the cast bracket. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
easy e Samba Member
Joined: May 28, 2008 Posts: 3942 Location: 1 hr north of Santa Barbara
Posted: Sun Jan 27, 2019 4:04 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
Since the front is out... I’d get underneath in the front of the bus & pull the cable forward a few feet.
Then get a small piece of wood to place on the rear Bowden tube opening... tap it with a hammer. I know, there’s tons of room... haha
If it doesn’t budge... I’d try to free up motion by twisting it with a smaller pipe wrench or faucet wrench.. adjacent to the cast piece, on the front side of it. _________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
Posted: Sun Jan 27, 2019 4:18 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
ok got it on. new problem. should i be able to thread the washer on without moving the clutch rod on the transmission? right now the end of the clutch cable barely makes it through the eye of the clutch rod. I have to pull the clutch rod forward to get eniugh thread to put on the wingnut but i cant put two hands up there to both pull the clutch rod forward and put the wingnut on.
its a brand new wolfs west cable. _________________ -Alex |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15490 Location: Casa de Oro, California
Posted: Sun Jan 27, 2019 7:17 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
| mauibarber wrote: |
its a brand new wolfs west cable. |
Do you have a bungee cord holding the clutch pedal up? |
roadkingdoc Samba Member
Posted: Sun Jan 27, 2019 7:36 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
| pull the lever forward and put something behind it to brace it. you can also loosen the cable up front and push it backward to get it started |
Posted: Sun Jan 27, 2019 10:19 pm Post subject: Re: I can't get my Bowden Tube off. What am I doing wrong. |
Lots of posts on doing this repair on the side of the road. I have no idea what they are talking about. Needed a strap lock just to get the clutch rod back enough so I could put the nut on.
Had to jack the bus up at least a foot so I could get under it.
How on earth does anybody do this "on the side of the road" _________________ -Alex |
