Exhaust ...stock or what?
ghiafreek
ghiafreek is offline
PostPosted: Sat Jul 13, 2019 8:35 am    Post subject: Exhaust ...stock or what? Reply with quote
Excuse me for not knowing but by owning a vanagon, much less a subi conversion, is new to me. I noticed an exhaust leak this morning and found the culprit. Looks like the catalytic converter has cracked at mount near muffler. First off does this all look stock exhaust system for what would of been for the previous 2.1L? Its a 2.5 subaru conversion. Ultimately, I need to know what catalytic converter to buy.
thanks for your help.
Mikesarge
Mikesarge is offline
PostPosted: Sat Jul 13, 2019 8:52 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
If not stock, it looks designed to fit in the stock location, more or less. The muffler looks like a gowesty unit, but it’s hard to tell.
The cat looks stock to me, so you could buy a regular replacement and be fine most likely.
However, what happened to me was, once I got my cat off, I noticed rust holes in my muffler, then in my (old smallcar conversion) headers. Now my whole exhaust system is new. All this to say, take a close look at each component before you order parts, could save you some downtime.
1986 Syncro westfauxlia EJ-frankenmotor
1980 911 SC 3.1
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Jul 13, 2019 9:32 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
I recently replaced everything (Y-pipe, cat, muffler) with components from Rock Auto (brand Walker). Not high end performance stuff but it is just an exhaust and a simple enough task if you have new parts, gaskets & bolts.
Mine is a WBX but I agree, what you have looks very like and original Vanagon system.
ghiafreek
PostPosted: Sat Jul 13, 2019 9:42 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
Thanks. Helps a lot. I will double check all before buying. Does sound pretty meaty with a hold in the cat. vroom..vroom!!
davideric9
davideric9 is offline
PostPosted: Sat Jul 13, 2019 9:15 pm    Post subject: Re: Exhaust ...stock or what? Reply with quote
Mostly stock, but I have never seen vanagon with two O2 sensors in the catalytic converter.
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
VicVan
VicVan is offline
PostPosted: Mon Jul 15, 2019 8:59 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
I put in the GoWest stainless steel exhaust, with cat. It looks quite like the one on the pics here. And The cat does have two ports. On mine, one port is not used.
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
jberger
jberger is offline
PostPosted: Mon Jul 15, 2019 9:09 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
Ditto.. I'm guessing he has an OBD2 subi swap, pre and post cat sensors. He'll have to have an extra bung welded to any Cat he buys.
J
danfromsyr
danfromsyr is offline
PostPosted: Mon Jul 15, 2019 11:17 am    Post subject: Re: Exhaust ...stock or what? Reply with quote
J
Abscate wrote:
