Starting issue
cdn_squareback
cdn_squareback is offline
PostPosted: Sat Sep 21, 2019 5:55 pm    Post subject: Starting issue Reply with quote
1971 squareback with a fresh 1776 twin carb rebuild.
pertornix svda 186504
flamethrower 1 coil
new napa battery, fresh gen rebuild
28 deg adv at 3000rpm
having an issue at hot start. went on our first road trip 250 km to a vw show near Montreal, drove for about 2 hours, stopped for fuel, no issue
drove another half hour, 45 min to a Porsche collector and the car wouldn't start after sitting for 20 min. cranks slow, almost like a dead battery.
bump start the car, drove another 20 km to the show, parked for 3-4 hours. starts fine
drove home, straight drive no stops, got home, tried to re start the car as soon as i parked, same issue cranks slow as if the battery is dead, no start.
waited 45 min, started fine. i haven't touched the starter yet, i cleaned all connections when i having charging issues a month ago.
anyone have this issue before i drop $300 cdn on a new gear reduction starter?
thanks
old_man
old_man is offline
PostPosted: Sat Sep 21, 2019 6:01 pm    Post subject: Re: Starting issue Reply with quote
What's the condition/age of the battery? I think starting a motor hot is more taxing than starting a motor cold. I've had a car that could start cold but not hot be remedied by a new battery. You could always try a booster pack/jump start the next time it happens....costs nothing.
Hopefully it's not something more serious like the engine being too tight or what have you.
Where in Canada are you? I have a working starter you could borrow.
cdn_squareback
PostPosted: Sat Sep 21, 2019 6:32 pm    Post subject: Re: Starting issue Reply with quote
battery is new, about 2 months old
gt1953
gt1953 is offline
PostPosted: Sun Sep 22, 2019 6:47 am    Post subject: Re: Starting issue Reply with quote
Check the charging of the battery with engine running. Check voltage before and after running.
72 type 1
72 Squareback
cdn_squareback
PostPosted: Sun Sep 22, 2019 7:46 am    Post subject: Re: Starting issue Reply with quote
running, its bounces anywhere for 13.4 to 14.2, when i try and start it after it being hot, my volt gauge is reading 12.4 to 12.6 car on, engine off. oil temp around 200
old_man
old_man is offline
PostPosted: Sun Sep 22, 2019 8:33 am    Post subject: Re: Starting issue Reply with quote
What kind of starter do you have in there? The self supporting kind or the one that needs a bushing? What's the condition of the bushing. Searching on these forums has led to a thread or two about it causing problems when hot.
The only other thing I can think of that you could try, besides cleaning all electrical connections and ground, is to put voltage directly to the solenoid.
Or you may just need rebuilt starter. Do you know the history of your starter?
Generic remanufactered self supporting starter at Napa Canada is about $120, $95 for the bushing kind. Less if you do the RockAuto thing.
Bobnotch
Bobnotch is offline
PostPosted: Sun Sep 22, 2019 10:07 am    Post subject: Re: Starting issue Reply with quote
Sounds like it's vapor locking at the fuel pump. Mine did that before I replaced the mechanical pump with an electric one. The lay up time is almost right on the money for a cool down of the pump.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Tram
Samba Socialist
Tram is offline
PostPosted: Sun Sep 22, 2019 10:44 am    Post subject: Re: Starting issue Reply with quote
Could be this- could also be that the base timing at cranking speed is too advanced at the engine is trying to overcome hydro lock when hot. This is actually quite common on 6v cars but I have seen it a few times with 009 and 12v. Next time it happens try retarding the timing a bit and see if it then cranks over faster.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
cdn_squareback
PostPosted: Sun Sep 22, 2019 12:18 pm    Post subject: Re: Starting issue Reply with quote
bought the car 4 years ago, never touched the starter.
cdn_squareback
PostPosted: Sun Sep 22, 2019 12:19 pm    Post subject: Re: Starting issue Reply with quote
Electric fuel pump mounted on the front beam
cdn_squareback
PostPosted: Sun Sep 22, 2019 12:34 pm    Post subject: Re: Starting issue Reply with quote
update
went for a half hour drive today, got up to about 165 deg and started as soon as i parked, spun nice and fast.
seems the issue is when the temp is close to the 200 mark
Erik G
Erik G is offline
PostPosted: Sun Sep 22, 2019 3:04 pm    Post subject: Re: Starting issue Reply with quote
Tram may be right. Those pertronics svda's are junk. They don't advance right, so if you are timed at high rpm, they are pretty high at idle.
The wires, the rubber grommet, the vacuum linkage all need to be worked on so if it's straight out of the box, that's part of the issue.
Yes, definetly the self supporting starter is a good upgrade
cdn_squareback
PostPosted: Sun Sep 22, 2019 6:08 pm    Post subject: Re: Starting issue Reply with quote
the wires and grommet have already been fixed as i had to replace the pick up due to wires not being properly placed at the factory. i have not touched the linkage yet. what should i look for?
i have been questioning if i'm pulling enough vacuum from both the 34ict. i have a vacuum line running from each base to a T then to the dizzy. i was actually thinking of tapping into the balance tube.
Erik G
Erik G is offline
PostPosted: Mon Sep 23, 2019 7:56 am    Post subject: Re: Starting issue Reply with quote
some just need better greasing but I had to pull it off and use a bosch one once, nothing would make the vacuum right
Intrinsic
Intrinsic is offline
PostPosted: Tue Sep 24, 2019 7:28 am    Post subject: Re: Starting issue Reply with quote
You could try insulating the starter with an insulating wrap. These are quite inexpensive and will help to ascertain if your starter is being overheated by the engine cooling air discharge.
