Dash Face Installation – Adhesive?
Sofia74
Sofia74 is offline
PostPosted: Fri Dec 06, 2019 3:22 pm    Post subject: Dash Face Installation – Adhesive? Reply with quote
We are ready to install the dash face in our 1974 KG Coupe. Several folks have referred to the installation but I haven’t read how it is attached, by that I mean is it glued and clamped? If so, what is the recommended glue? Construction adhesive? Anything that lists plastic as appropriate on the label?
Thanks,
Matt
djkeev
djkeev is offline
PostPosted: Fri Dec 06, 2019 3:38 pm    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
You will find this thread informative........
https://www.thesamba.com/vw/forum/viewtopic.php?t=335553&highlight=dash+woodgrain
3M #90 spray adhesive.
Dave
Ghia
Vanagon
Beetle
Sofia74
Sofia74 is offline
PostPosted: Fri Dec 06, 2019 3:47 pm    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
Thanks. I'm sure the answer is buried in a few threads but I really appreciate you narrowing it down for me.
Matt
Braukuche
Braukuche is offline
PostPosted: Fri Dec 06, 2019 7:29 pm    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
Matt
I used the stuff KGPR sells and it's crap.
I've never been happy with 3Ms stuff.
The best canned spray adhesive I've ever used is Keyston high temp spray adhesive.
https://keystonbros.com/keyston-hi-temp-heavy-duty-trim-adhesive-sp092-14-500.html
Recommended by the Late great Bill May.
I used it 16 years ago or so on my 1960 double cab to glue bubble wrap to the roof and recently tried to remove it, the wrap tore before the glue would give. I wish I had used it on my wood grain dash! Ugh.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
runamoc Premium Member
runamoc is offline
PostPosted: Sat Dec 07, 2019 8:12 am    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
I used double-sided sticky tape
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
carlos_magnum
carlos_magnum is offline
PostPosted: Tue Dec 10, 2019 12:02 am    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
Weldwood contact cement in another solution though this product is not so forgiving if an unwanted misalignment occurs.
bhartwell59
bhartwell59 is offline
PostPosted: Tue Dec 10, 2019 6:31 am    Post subject: Re: Dash Face Installation – Adhesive? Reply with quote
carlos_magnum wrote:
Weldwood contact cement is another solution though this product is not so forgiving if an unwanted misalignment occurs.
I used this to glue the plastic upper door covers (black pebble grain) to my vert doors. It does require some forethought and a steady hand.
'74 Zambezi green Ghia vert, autostick, 103k
'87 Jeep Wrangler, 4.2, 334k
