Lazy Battery Light Fix for Vanagon
Italjohn
Italjohn is offline
PostPosted: Thu Jul 02, 2020 12:39 am    Post subject: Lazy Battery Light Fix for Vanagon Reply with quote
Anyone know what's inside this kit from Gowesty?
It looks like a big resistor?
How does it work?
https://www.gowesty.com/product/-/24031/alternator-charge-initiation-kit?v=
Follow me on facebook: https://www.facebook.com/norwayvanagon
My youtube channel: https://www.youtube.com/c/Italjohn
Instagram: https://www.instagram.com/italjohn/
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
a2wolfsburggli
a2wolfsburggli is offline
PostPosted: Thu Jul 02, 2020 6:17 am    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
Looks like a fix for something that's not really a problem.
Current: '74 Type 181 | '16 Audi Q5 3.0T S-Line Chipped to ~460hp
Past:'87 Westfalia | '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense
jlrftype7
jlrftype7 is offline
PostPosted: Thu Jul 02, 2020 6:29 am    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
I thought it was a capacitor kit.
‘84 Tin Top - Hilga....Auto
Italjohn
Italjohn is offline
PostPosted: Fri Jul 03, 2020 1:38 am    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
I think it's a resistor in parallel with the red led on the dash?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Jul 03, 2020 4:46 am    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
That is the right idea but it is installed in the engine compartment wiring box where there is a stock black wire from circuit 15 and a stock small blue wire to the alternator field winding connector.
Mark
jlrftype7
PostPosted: Fri Jul 03, 2020 3:43 pm    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
Mark
In that schematic, it appears to show a resistor from the factory already in the cluster , parallel with the excite/ warning bulb circuit.
How does putting another resistor all the way back in the engine compartment wiring help with the charging delay of start up idle speed, where you need to speed up the engine with that blip of throttle to get the Alternator working. Confused Confused
crazyvwvanman
PostPosted: Fri Jul 03, 2020 4:42 pm    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
Different versions of the instrument cluster blue foil provide different amounts of excitation current. Later versions provide more, 87+ I think.
I'm not endorsing the use of the GW device, just helping explain it.
As GW mentions in their product description there are reasons why some vans are slower than others to turn off the alternator warning light after starting the engine. I'd prefer to fix the real issue if there is one on a given van.
GoWesty aux battery relay kits are sometimes hooked up such that they add a large load to the alternator blue wire circuit so I consider this device to be something to help them with another of their products that I don't think highly of.
Mark
Italjohn
Italjohn is offline
PostPosted: Fri Jul 10, 2020 6:18 am    Post subject: Re: Lazy Battery Light Fix for Vanagon Reply with quote
How does this work on modern cars, as they don't need to rew the engine to make it charge?
The alternator have still the same working way.
