distributor as cam sensor options...
Chickensoup
Chickensoup is offline
PostPosted: Sat Jul 25, 2020 8:30 pm    Post subject: distributor as cam sensor options... Reply with quote
hi there,
so when running sequential, you need a cam sensor of some sort, or a way to tell the ecu where #1 piston is at... duh
so, what kind of distributor can i use? i see that the late 2.0 type 4 distributors already have a hall sensor, but will the body and shaft fit into a type 1 case? if so, then can i just remove 3 of the windows?
or, can i take any distributor, strip it, lock it, and put a magnet on the rotor and make a custom cap for it, that is drilled and tapped in the right spot for a vr sensor, that way, when the rotor is pointing at the number 1 position, the sensor will send a signal to the ecu?
ive also seen someone add an internal magnet on the cam gear and drill and tap the case for a hall sensor. does anyone have any experiance doing so.
i saw this here,
https://ub-52.blogspot.com/2010/01/blog-post.html
im also open to other ideas, but i would like to use a distributor that has the same shaft as a type 1 so it will drop right into the current hole.
thank you
aiden
'65 Tourist Delivery Build
'66 RIP
Xevin Premium Member
Xevin is offline
PostPosted: Sat Jul 25, 2020 9:23 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Do you have a 1979-83.5 aircooled bus/van distributor with all the fixin’s on the shelf??
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
[email protected]
john@aircooled.net is offline
PostPosted: Sat Jul 25, 2020 9:48 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
https://www.cbperformance.com/product-p/7073.htm
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Chickensoup
PostPosted: Sun Jul 26, 2020 7:54 am    Post subject: Re: distributor as cam sensor options... Reply with quote
I know, but they have been out of stock for months and when I talked to him he says it would be AT least two months. And the other one that another company makes is out of my price range.
'66 RIP
Chickensoup
I do not. Why?
'66 RIP
Krochus
Krochus is offline
PostPosted: Sun Jul 26, 2020 8:00 am    Post subject: Re: distributor as cam sensor options... Reply with quote
I have the micro cam sync on mine.
After getting the tune dialed in ive never bothered to make the switch to sequential
Sequential injection and spark really isn’t nearly as big a deal as it gets made out to be
1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500
Chickensoup
PostPosted: Sun Jul 26, 2020 4:06 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Hmmmmm, I though more people would of done this Think
'66 RIP
modok
modok is offline
PostPosted: Sun Jul 26, 2020 4:28 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
If you just grind three of the four lobes off the points cam it would be a mechanical hall sensor. Can be wired to produce a 0-12 volt or 0-5 volt signal.
THe rest of the distributor could be used as....a distributor.
Using points to run modern electronics.....weird eh? but I do it all the time. Works good.
Compufire with one magnet? Wink
Chickensoup
PostPosted: Sun Jul 26, 2020 4:40 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Ok madok, hand over the rest of the info... hand it over nice and slow and I wont shoot you Shocked gee, take a joke man! Seriously, this, I'm interested in. Time for me to buy a cheap big cap 40hp distributor and get on it! My biggest question is, how to you connect the signal from the distributor to the other end? Can I reverse engine-nerd something?
Thanks
'66 RIP
modok
modok is offline
PostPosted: Sun Jul 26, 2020 5:32 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
40 or 60 ohm resistor between 12v ignition power and points.
When points are open, 12 volts
when closed, 0 volts
similar to this
Chickensoup
PostPosted: Sun Jul 26, 2020 6:21 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
similar to this
thanks a ton Madok, do you think there would be any advantage to use the same principle, but with a cheap electronic ignition module/ a real hall sensor?
thanks
'66 RIP
rayjay
rayjay is offline
PostPosted: Sun Jul 26, 2020 6:38 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Our 5.9 / 360 Magnum died in the driveway last week. I did a lot of YT and found scannerdanner who has some great trade school vids on troubleshooting modern cars. The Dodge uses a "square wave, 5 volt, pull down, hall effect sensor for the cam position sensor in the dist and also for the crank position sensor. You CAN test them with a volt meter but a scanner is best.
I looked for pics of the inside of the dodge dist. The rotor is basically solid for 1/2 of the diameter then open for the other half. I was expecting windows. I guess the leading edge of the rotor is the signal. So it really is determined by what your computer can be programmed to read.
BTW, after testing the cam position sensor and crank sensor both were good and the 5 v bus was not shorting out so I ordered a rebuilt computer and it fired up instantly. WOOTT !!
Here is a vid with pics of the inside of the dodge dist.
https://www.bing.com/videos/search?q=dodge+5.9+v8+...orm%3DQBVR
modok
modok is offline
PostPosted: Sun Jul 26, 2020 6:49 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Yes you could use a compufire, I would still add a resistor as a "dummy load".
It would just go across the two wires.
the nice thing about that.... is it could be 100% reversible.
Tho, I like the simplicity of the points idea.
They last an incredibly long time if just used as a 'sensor" instead of handling all the power.
I've been using the same set of points since 2012, and they weren't new then.
5-6 days a week.
You could also use maybe the sensor from a crane xr700 ignition kit, which is an optical trigger, I'll have to look that up.... but I think it would be even easier and maybe cheap cause nobody likes those.
Chickensoup
PostPosted: Sun Jul 26, 2020 8:49 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
i swear i have ptsd from dodge engines. sometimes at night, when im trying to sleep, i can hear a dodge ticking under my bed Laughing glad to hear your truck isnt a ticking time bomb like my dads lol.
madok, i agree with you on just keeping it simple for now and sticking with points. if i want to use a hall sensor later, its just a bolt on basically so no biggie.
my next question if you dont mind madok: so, your a machinist, how would you go about removing the three extra lobes? just hand grind them down on a wheel? also, would it be optimal to alter the shape of the lobe? from my understading, you want to send the signal out, right when, or right before, the number one piston is at tdc. will the cam lobe contact the points too late? or in other words, is the lobe too gentle? meaning that there is too much duration? am i over thinking this? Think
'66 RIP
modok
modok is offline
PostPosted: Sun Jul 26, 2020 9:00 pm    Post subject: Re: distributor as cam sensor options... Reply with quote
Yeah just grind em down.
Good question.... i don't know for sure...... maybe nobody does know, but I THINK
IF the computer is equally capable of reading a hall or a VR sensor, I think it will be able to work fine with points.
Xevin is offline
PostPosted: Mon Jul 27, 2020 10:07 am    Post subject: Re: distributor as cam sensor options... Reply with quote
Chickensoup wrote:
I do not. Why?
Could be valuable to some Bay/Van owners that use those and want their car all original. Was just a thought.
Keep on Busin'
SGKent wrote:
Dale M.
Dale M. is offline
PostPosted: Mon Jul 27, 2020 10:25 am    Post subject: Re: distributor as cam sensor options... Reply with quote
Could use Compu-Fire module with 3 of the 4 magnets removed, leaving only the one magnet for #1 TDC ...
Dale
