victorybug Samba Member
Joined: April 09, 2019 Posts: 6 Location: Long Island, NY
Posted: Sun Oct 25, 2020 9:34 am Post subject: Reduction box disc brake conversion |
| i have searched up and down and cant find any info on putting disc brakes on small nut reduction boxes, i saw someone did a irs reduction box set up with disc brakes but they did not really specify how they did the disc brakes any help would be much appreciated i do not want to get rid of the reduction boxes |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4175 Location: San Diego
Posted: Sun Oct 25, 2020 11:18 am Post subject: Re: reduction box disc brake converstion |
| There arent any kits for this. Probably because there isnt enough room |
Posted: Mon Oct 26, 2020 12:17 pm Post subject: Re: reduction box disc brake converstion |
| not necessarily looking for a kit more along the lines if anyone know whats in the way and whats involved in it, i have read somewhere cant remember where that you can mod a type 3 kit but i have no more info then that |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7122 Location: Lawrenceville, Ga
Posted: Mon Oct 26, 2020 12:54 pm Post subject: Re: reduction box disc brake converstion |
| victorybug wrote: |
considering that there is so much going on on a reduction box rear, like the emergency brake for example, are you sure you need disk brakes on the rear?
are you going racing? disk brakes up front should give you plenty of stopping power? _________________ regards
Uli
Posted: Mon Oct 26, 2020 1:07 pm Post subject: Re: reduction box disc brake converstion |
| i am not going racing but i dont like having to adjust the drums all the time, the fronts do provide enough stopping power, i would not mind more, and how much stuff do we actually put on our cars that we actually need, i just want to set up discs on the boxes so its discs all around and never have to adjust anything |
Posted: Mon Oct 26, 2020 1:09 pm Post subject: Re: reduction box disc brake converstion |
| victorybug wrote: |
gotcha, that is why i asked. _________________ regards
Uli
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Mon Oct 26, 2020 1:22 pm Post subject: Re: reduction box disc brake converstion |
| Russ at Old Speed had said he might attempt a kit in the future, might want to check with him. He is located in Southern California. |
Posted: Mon Oct 26, 2020 1:52 pm Post subject: Re: reduction box disc brake converstion |
| do you have any contact info for russ |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1595 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Mon Oct 26, 2020 2:53 pm Post subject: Re: reduction box disc brake converstion |
| Sounds like a good project to undertake. It comes up every so often, but Ive need seen one. Keeping it inside the fender wells is part of the issue |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3441 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Oct 27, 2020 8:54 am Post subject: Re: reduction box disc brake converstion |
| victorybug wrote: |
but i dont like having to adjust the drums all the time...
The amount of time you will spend cobbeling something together will eat up the same amount of time as 10 years worth of brake adjustments. Plus the time spent inspecting and adjusting brakes might lead you to find other issues that might no be caught with a set it and forget it mentality.
If the fronts already off the ground for a king and link pin PM a brake adjustment is only about 10 extra minutes. If you lift the rear to do a valve adjustment another 10 minutes for a rear brake adjustment. |
Posted: Tue Oct 27, 2020 2:54 pm Post subject: Re: Reduction box disc brake conversion |
I think Russ at Old speed did some prelim work on this, but never got anywhere. The RGB case makes mounting a caliper mount nearly impossible unless the wheel is spaced wayyy outward. Then there is the Ebrake issue
If your willing to go straight axle, then it can be done - no rgb's |
