LancastercountyJim Samba Member
Posted: Wed Nov 11, 2020 8:16 am Post subject: Headlights and wipers all of a sudden not working. |
I bought a 72 Super Beetle a few months back and have been working on getting it back on the road. A couple weeks ago the headlights and wipers both worked well, but all of a sudden neither are working. Note: the side marker and brake lights work & the fuses all look to still be working and in tact.
Before I go replace the headlight switch and wiper switch, is there an easier explanation as to why they both went out at the same time?
I find it surprising both happened to go out the same week after all these years, I appreciate the feedback! - Jim |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2427 Location: Colorado
Posted: Wed Nov 11, 2020 9:03 am Post subject: Re: Headlights and wipers all of a sudden not working. |
Could be ignition switch related, since both of those items only work with the key "ON". Do you know how old your switch is? _________________ 1972 Standard Beetle
1969 Baja Beetle |
Posted: Wed Nov 11, 2020 11:13 am Post subject: Re: Headlights and wipers all of a sudden not working. |
| Yes, that was one of the earliest items I replaced, just about 2 months ago. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33129 Location: Hot Arizona
Posted: Wed Nov 11, 2020 3:23 pm Post subject: Re: Headlights and wipers all of a sudden not working. |
| LancastercountyJim wrote: |
| Before I go replace the headlight switch and wiper switch |
Before you go replace the headlight switch and wiper switch - TEST THE SWITCHES !!!!
We don't just throw parts at a problem here !!!
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Nov 11, 2020 3:32 pm Post subject: Re: Headlights and wipers all of a sudden not working. |
Five minutes spent with a trouble light determining where power is and isn't getting where it should would go a long way toward fixing the problem.... or you can just guess and throw parts at it, that works sometimes as well. _________________ 1960 Ragtop w/Semaphores "Inga" |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16603 Location: North Florida, USA
Posted: Wed Nov 11, 2020 3:52 pm Post subject: Re: Headlights and wipers all of a sudden not working. |
Find the black/yellow "X" wire coming from the ignition switch. This wire comes thru into the trunk along with the other wires from the ignition switch. The wire should run to the INPUT side of the #10 fuse. Also at the INPUT side of #10 should be another black/yellow wire that runs to the "X" terminal on the headlight switch. The OUTPUT side of #10 fuse runs to the wiper switch/motor.
If there is a disconnect between the ignition switch and the #10 fuse INPUT both the wipers and headlights would be affected.
The black/yellow "X" wire is only powered when the ignition switch is in the ON/RUN position. Turn the key to this position and then test the #10 INPUT for 12v using a test lamp or VM. Wiggle the key to see if there is intermittent voltage or voltage only is a certain position. If it is, you have a bad ignition switch. It is likely the internal contacts have been burnt from the current flow. If you only replaced the switch a couple months ago consider returning it or opening it up and check the internals. If it is just the contacts getting burnt you can clean them up with a wire brush/sandpaper and add a relay (similar to a Hard Start Relay) to the circuit to take the current load off the electrical contacts in the switch. _________________ AshMan40
Posted: Thu Nov 12, 2020 7:10 am Post subject: Re: Headlights and wipers all of a sudden not working. |
| Appreciate it guys, I'll try all of these tips. |
Posted: Sat Nov 14, 2020 2:24 pm Post subject: Re: Headlights and wipers all of a sudden not working. |
Thanks Ashman40, that was exactly the problem. The black/yellow wire from the ignition switch was disconnected.
Tested it, headlights and wipers come on perfectly.
Now here comes the hard part... as I’m just about to celebrate and mark a Win for the day, I take the keys out of the ignition and the engine stays on, lights and all?! I had to choke the carb in order to turn the engine off.
What did I do?! |
Posted: Sun Nov 15, 2020 2:15 pm Post subject: Re: Headlights and wipers all of a sudden not working. |
Sounds like you wired your ignition HOT. Check your diagrams, wire for wire. _________________ 1972 Standard Beetle
1969 Baja Beetle |
