Active Split Bus Registry?
id'r
id'r is offline
PostPosted: Thu Dec 31, 2020 9:46 pm    Post subject: Active Split Bus Registry? Reply with quote
Is there an active split bus registry? A quick forum search pointed to vintagebus.com as being the most populated, but it appears this site is no longer. A few other projects started also, but with dead links.
Was thinking about some of those unknown m-codes and using a searchable database/registry to help crack some codes.
425 025 797
UP 2412 454483 502xxxx
https://www.thesamba.com/vw/forum/viewtopic.php?t=699902&highlight=65+barn+find
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Dec 31, 2020 10:12 pm    Post subject: Re: Active Split Bus Registry? Reply with quote
Vintagebus.com
Quote "Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later."
So looks like it is not lost.
In Stereo, Where Available!
bobrk
bobrk is offline
PostPosted: Fri Jan 01, 2021 3:33 am    Post subject: Re: Active Split Bus Registry? Reply with quote
Eric&Barb wrote:
Vintagebus.com
Looking on archive.org, it looks like it's been down since 2017.
1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats
thom
thom is online now
PostPosted: Fri Jan 01, 2021 8:30 am    Post subject: Re: Active Split Bus Registry? Reply with quote
bobrk wrote:
Eric&Barb wrote:
Vintagebus.com
It hadn't been maintained since before that. I just assumed someone else would pick up where I left off with the registry. I gave Lind a copy of the data.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Clara Premium Member
Clara is offline
PostPosted: Fri Jan 01, 2021 11:07 am    Post subject: Re: Active Split Bus Registry? Reply with quote
thom wrote:
bobrk wrote:
Eric&Barb wrote:
Vintagebus.com
It sounds like someone could pick it up if they wanted.
If someone wants to host a split bus registry, they might ask Lind about the info for his Westfalia registry. He used to have a site with a registry of pressed bumper Westies, but that was before Greg and I picked up the Montana '56.
earlywesty
earlywesty is offline
PostPosted: Sun Jan 03, 2021 6:51 am    Post subject: Re: Active Split Bus Registry? Reply with quote
Clara wrote:
thom wrote:
bobrk wrote:
Eric&Barb wrote:
Vintagebus.com
Whats involved in maintaining the westfalia registry? I know nothing about doing this type of work but would love to see the pressed bumper westfalia registry up and running. I might be convinced to take it on....Lind, details?
