1967vwroberto Samba Member
Posted: Sun Jan 10, 2021 12:08 pm Post subject: white smoke |
Had the engine and trans rebuilt in my 1967 bug a few years back. Recently been having white smoke at start up? Also huge MPG drop.
Any suggestions would be appreciated.
Also on bumpy roads I'm hearing a clunk, thump or bump from the rear? I think maybe swing arm?
Anybody have a suspension expert here in SoCal? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11201 Location: Oregon
Posted: Sun Jan 10, 2021 12:15 pm Post subject: Re: white smoke |
White smoke = Water.
Blue smoke = Oil.
Black smoke = Fuel.
Are you sure it's white?
Regarding the thunk over bumps. Read this thread. It may be your issue.
https://www.thesamba.com/vw/forum/viewtopic.php?t=643577&highlight=thunk
Welcome to the samba. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
joemama Samba Member
Joined: February 09, 2006 Posts: 1667 Location: La Crescenta, California
Posted: Sun Jan 10, 2021 2:31 pm Post subject: Re: white smoke |
As Rustavenger posted, white smoke is water. Remove the oil fill cap, and if you see a lot of nasty brown stuff, that tells you its water, usually from too many short drives that dont allow the oil to get hot enough to burn off any condensation.
Regarding the thunk, I have experienced a thunk from shocks fitting loose on the bolts possibly due to worn shock bushings, and have also experienced a thunk from worn out, and missing rubber pads where the body bolts to the frame, near the top of the torsion/upper shock area. |
oprn Samba Member
Joined: November 13, 2016 Posts: 14846 Location: Western Canada
Posted: Sun Jan 10, 2021 5:13 pm Post subject: Re: white smoke |
You are not telling us where you live so or what the weather is like. In my part of the world every internal combustion engine produces white smoke all winter long. And yes you use more gas in the winter. _________________ Our cars get old, we get old but driving an old VW never gets old! |
