footwell repair
space
space is offline
PostPosted: Sun Jul 11, 2021 8:50 pm    Post subject: footwell repair Reply with quote
im doing the bedliner "mod"
and am wondering what peeps are using to fill the factory holes once the pads are gone?
TIA
PS did a goog search and came up empty
T
82 westy
w:
2.5 JDM Subie
Rear discs
jimf909
jimf909 is offline
PostPosted: Sun Jul 11, 2021 9:02 pm    Post subject: Re: footwell repair Reply with quote
What's the bedliner "mod"? Bedliner has so many applications nowadays.
- Jim
Butcher wrote:
Guilty as charged.
kaalualu
kaalualu is offline
PostPosted: Sun Jul 11, 2021 10:27 pm    Post subject: Re: footwell repair Reply with quote
I glued some old tokens underneath, covering holes, then sprayed the undercoating both sides.
'84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel
0cean
0cean is offline
PostPosted: Sun Jul 11, 2021 10:48 pm    Post subject: Re: footwell repair Reply with quote
Ebay search for fire wall grommets. Get the assorted pack.
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
djkeev
djkeev is offline
PostPosted: Mon Jul 12, 2021 3:31 am    Post subject: Re: footwell repair Reply with quote
Wow!
Thanks for the reminder!
Both of my front door foot wells are rusty, not to the point of being gone but they are indeed porous and you can see the road go by.
I need to properly weld in some new metal but I can see that this proper fix probably won't happen before the snow flies in 2021.
So, as a gap stop measure, slow the decay.
I am NOT a fan of silicones or fluid films or other creeping rust stop if you plan to properly make repairs in the future. The residue of such products is quite simply a PITA to clean up!
I think I will simply scrape off the loose scale and hit it with a few coats of Rustoleum Rusty Metal Primer.
I will then probably screw on a sheet of metal with a non silicone caulk between the new metal and rusty step to block water ingress.
Easy to do, easy to remove and no nasty residue to clean up when the time rolls around for a proper repair.
The genius who designed that foot pad attachment should be strung up!
Dave
Ghia
Vanagon
Beetle
joetiger Premium Member
joetiger is offline
PostPosted: Mon Sep 27, 2021 11:57 am    Post subject: Re: footwell repair Reply with quote
djkeev wrote:
Wow!
Dave
Have you done your temporary repair yet, Dave? I'd love to see how it turns out.
Joe T.
'02 Baja-ish Beetle "Bubbles"
leecat
leecat is offline
PostPosted: Mon Sep 27, 2021 12:12 pm    Post subject: Re: footwell repair Reply with quote
We take out both rubber footwell covers after every trip and clean and dry both metal and rubber. I agree that's an awful design - practically built to guarantee rust. :/
PDXWesty
PDXWesty is offline
Here's a thread you can read for examples:
https://www.thesamba.com/vw/forum/viewtopic.php?t=394760
89 Westy 2.1 Auto
joetiger is offline
PostPosted: Mon Sep 27, 2021 12:18 pm    Post subject: Re: footwell repair Reply with quote
Thanks. My footwells have seen better days but I probably won't do the full repair (who am I kidding--I probably won't get the full repair done) until spring.
Joe T.
Snoww_
Snoww_ is offline
PostPosted: Tue Sep 28, 2021 9:51 am    Post subject: Re: footwell repair Reply with quote
I pulled the rubber out and sealed the holes with some JB Weld SteelStick. A little janky but I'm just going to sand it down and cover with bedliner so ndb to me.
1991 Tiico Vanagon Carat
1961 Baja Bug
djkeev
djkeev is offline
PostPosted: Tue Sep 28, 2021 11:46 am    Post subject: Re: footwell repair Reply with quote
I’ve perforations on both steps.
I need to do a quick and dirty repair for the coming Winter.
It will probably be a fast and dirty fiberglass patch for now.
I know you can buy the patch panel from BusDepot But I think I’ll form my own to weld in eventually, it isn’t beyond reconstruction.
Dave
Ghia
Vanagon
Beetle
4Gears4Tires
4Gears4Tires is offline
PostPosted: Wed Sep 29, 2021 7:42 am    Post subject: Re: footwell repair Reply with quote
Huh, I've never even thought about just welding the holes shut. They certainly do trap a lot of water below the rubber pad. I tried gluing it down to keep moisture out, but there's no reason I can't weld the holes shut, cut the plugs off the rubber cover, and then glue the cover down. Might reduce road noise too.
djkeev
djkeev is offline
PostPosted: Wed Sep 29, 2021 11:49 am    Post subject: Re: footwell repair Reply with quote
Some without welding abilities have epoxied electrical box “knock outs” to seal the holes.
Ghia
Vanagon
Beetle
