Main Seal Madness
Robw_z
Robw_z is offline
PostPosted: Sat Sep 04, 2021 9:28 am    Post subject: Main Seal Madness Reply with quote
I haven't been able to park in my driveway for 6 months because of a leaking main seal. According to GoWesty, the SABO brand is the holy grail of Main Seal quality:
They also have an article which basically states "No matter hard we tried main seals kept leaking until we found the SABO brand seals. But we're out of 'em now so buy some of our leaky ones please!":
https://www.gowesty.com/tech-article-details.php?id=60
Van-Cafe had reviews on the main seal they sell as recently as 12 months ago stating they received the SABO brand seal. So I tried to order one, making sure it was SABO before finalizing the order, and they are out of SABO. This leaves Victor Reinz or Elring. The seal I ordered from GoWesty is Victor Reinz. Reasons GoWesty states for these being inferior quality is they are thinner (Mine measures 10mm thick, not sure how thick the SABO is), and the "choke spring" is weaker.
Victor Reinz seal received from GoWesty:
All I can think to do now is compensate for poor seal quality with attention to detail on installation. GoWesty sells a "main seal install kit" which imitates what is recommended in the Bentley:
I'll also probably polish the flyweel:
Since all Buses and Vanagons used the same main seal from 1972-1991; you'd think there would be some more options out there in the aftermarket. Is anybody aware of anything? Does anyone with a SABO or Elring seal have some insight into the specs or quality comparisons with the Victor Reinz I have?
Bottom line is I only want to do this job once. Thanks for any input!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Sep 04, 2021 9:32 am    Post subject: Re: Main Seal Madness Reply with quote
My experience with with Type 1 engines and the Elring are superior to Victor Reinz. I've never had a leak from Elring. And the Victor Reinz seals just don't look as good.
With the amount of labor and time it takes to fix it a second time, I only use Elring.
Not sure if this applies to Vanagon engines but I doubt the quality differs much from Type 1s.
Good luck.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DanHoug
DanHoug is offline
PostPosted: Sat Sep 04, 2021 9:41 am    Post subject: Re: Main Seal Madness Reply with quote
that seal install tool will keep the new seal from getting distorted from hammer blows during installation. prolly worth $50 as they do tend to tip in and out during install.
the other thing to consider if you truly only want to do this once is install a Speedi Sleeve on the seal surface of the flywheel. they really work, are easy to install, and not too expensive given the labor of having to go back in again. i don't have the part number of the one needed but SKF has the charts to match your measurements.
-dan
www.thefixitworkshop.com
djkeev
djkeev is offline
PostPosted: Sat Sep 04, 2021 9:59 am    Post subject: Re: Main Seal Madness Reply with quote
Yeah........ I too am a SABO fan.
Whenever I get an overhaul kit tge first thing in the trash is the flywheel seal!
FCP usually has them........ but they show a backorder situation too.
Too bad........ I hate doing jobs like that twice!
10cent, intrepid overland? Has a blog where he describes how to prep the flywheel fir a new seal.
I HIGHLY recommend that you find it, read it and do as it says.
My recent engine "refresh" which is now pushing 9,000 miles is running the SABO seal and I followed the flywheel prep tips is dry ....... can't say the same for the transmission oil pan gasket though.......
Dave
Ghia
Vanagon
Beetle
9.5isCanadian
9.5isCanadian is offline
PostPosted: Sat Sep 04, 2021 11:05 am    Post subject: Re: Main Seal Madness Reply with quote
My buddy is resealimg his T4 WBX and just bought the rear main seal from the VW dealer. It’s full width with the elastomeric element inside.
Just my .02
9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi
