Greaser2 Samba Member
Posted: Sun Dec 26, 2021 3:12 pm Post subject: 1967 ignition removal |
I’ve gotten as far as pulling the mechanical key switch out but the electrical switch does want to slide out. Maybe only moves a 1/2 inch. Do I need to unsolder the thee wires first?
Porschedave Samba Member
Joined: July 01, 2004 Posts: 461 Location: Vancouver, Canada
EverettB  Administrator
Joined: April 11, 2000 Posts: 71534 Location: Phoenix 602
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4507 Location: Illinois
Posted: Mon Dec 27, 2021 8:54 am Post subject: Re: 1967 ignition removal |
I normally remove the entire column before removing the switch. It's easier to install/remove parts and see what I'm doing. |
Posted: Sun Jan 02, 2022 3:17 pm Post subject: Re: 1967 ignition removal |
Still can’t seem the get the switch to slide out, only goes about a 1/2 inch and stops. Feels like it’s hitting metal??
Posted: Sun Jan 02, 2022 3:36 pm Post subject: Re: 1967 ignition removal |
Well, I put the mechanical key switch back in and turned it a bit and it’s sliding more finally. |
Posted: Sun Jan 02, 2022 10:50 pm Post subject: Re: 1967 ignition removal |
Maybe the lock tab was sticking out?
You can see it at the top here sticking out:
I usually remove the ignition with the key in it as something to grab with my hand but also so the key is turned and not in the fully locked position where the lock tab pops out _________________ How to Post Photos
Posted: Mon Jan 03, 2022 1:45 pm Post subject: Re: 1967 ignition removal |
Exactly the issue |
57dbldoorpanel Samba Member
Joined: February 11, 2004 Posts: 115 Location: Yuma, AZ
Posted: Tue Oct 22, 2024 2:18 pm Post subject: Re: 1967 ignition removal |
Can the switch be removed with the lock tab in the locked position? Keys were lost and trying to get the numbers to re key. _________________ 1960 L346 L347 Standard |
rustyfastback Samba Member
Posted: Tue Oct 22, 2024 3:59 pm Post subject: Re: 1967 ignition removal |
A true ‘67 switch will have a “K” code tumbler that is removable. See the slot press the spring to remove the key part. Some photos where the key goes I would be able to tell. I have a lot of photos of those early switches in my gallery. See photo.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Wed Oct 23, 2024 1:55 pm Post subject: Re: 1967 ignition removal |
That happened to me on my 63 notch. I took the whole column off and sent it to Gabriel to put a new key in the original ignition. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
