Yannvanh Samba Member
Joined: November 07, 2020 Posts: 217 Location: Belgium
Posted: Sat May 07, 2022 9:02 pm Post subject: Straight axle conversion inner spacer |
Hi guys,
I am doing a Sa conversion on my 65 bus and made the axle tubes myself.
Now im in the proces of putting it all back together but i noticed that the inner spacer falls tot deep (i think) in the tube..
I can pull the axle itself a little bit and then the spacer will sit flush with the tube..
Am i doing something wrong or did i made the tubes to long?
I hope you guys van understand what im' saying here!
Thanks! |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3899 Location: Eastern WA
Posted: Sun May 08, 2022 4:54 pm Post subject: Re: Straight axle conversion inner spacer |
Which axles are you using? _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Ragtop Samba Member
Joined: November 23, 2003 Posts: 639 Location: Rio Rancho New Mexico
Posted: Sun May 08, 2022 7:38 pm Post subject: Re: Straight axle conversion inner spacer |
| Did you use short end castings? |
John Ghia Samba Member
Posted: Thu May 12, 2022 12:43 am Post subject: Re: Straight axle conversion inner spacer |
Yes i used the short end castings and made the axles the same way with the jig like the SA thread:
I use the long axle/long spline |
Vanell Samba Member
Posted: Thu May 12, 2022 4:43 am Post subject: Re: Straight axle conversion inner spacer |
| I measure the long housing with the bearing in, then I make the short end housing that length with also the bearing in, seems to me the problem you are having as the bearing seats differently in the long and short housing. Ian |
Posted: Mon May 16, 2022 10:53 am Post subject: Re: Straight axle conversion inner spacer |
| Vanell wrote: |
There's a difference of +- 4 mm so i think i have found the problem!
Gonna make a new inner spacer that's 4 mm wider from an old (wider) outer spacer with a lathe machine!
I also need spacers for early bug drums so need to trim the outer one 4mm down so the axle nut will fit!
Thanks guys! |
