Power mirror base broke (Fixed)
dobryan
dobryan is offline
PostPosted: Sun May 14, 2023 7:25 pm    Post subject: Power mirror base broke (Fixed) Reply with quote
O
n my way from Maryland to Syncro Solstice the drivers power mirror decided to leave the base. Luckily I saw it start to flop and was able to grab it before it decorated the highway at 70mph. I could only hold it against the window frame until the next exit.
When I arrive at my first days stop (friends place South of St Louis) I was able to see that the internal sleeve post had snapped off of the mirror housing. This piece is cast metal.
Because the piece is hollow in the center for the wiring I decided I could pull the wires and then use a bolt from the bottom up into the mirror housing. I did have to drill a big hole in the housing base to get enough clearance inside for the nylock nut.
It took a few hours of thinking and parts runs and several tries but in the end I saved the mirror. And I do not need the power function.
Dave O
The Western Syncro build
jimf909
jimf909 is offline
PostPosted: Sun May 14, 2023 8:29 pm    Post subject: Re: Power mirror base broke (Fixed) Reply with quote
Nice catch and nice fix.
I guess I should bookmark this post since I may have this in my future.
- Jim
Butcher wrote:
Guilty as charged.
montanasurfer
montanasurfer is offline
PostPosted: Sun May 14, 2023 8:56 pm    Post subject: Re: Power mirror base broke (Fixed) Reply with quote
https://shufti.blog/2011/10/05/vanagon-power-mirror-repair/
I had the same thing happen and I used this as a guide to fix it. Additionally you can buy bolts with holes drilled through the center, which makes this even easier.
1987 Vanagon GL - Wolfsburg Edition
dobryan
dobryan is offline
PostPosted: Mon May 15, 2023 5:37 am    Post subject: Re: Power mirror base broke (Fixed) Reply with quote
Nice!
Dave O
Sodo
Sodo is offline
PostPosted: Mon May 15, 2023 8:23 am    Post subject: Re: Power mirror base broke (Fixed) Reply with quote
An On-The-Road how-to with really nice pics !!!
....KTMs, GasGas, SPOT mtb
