Vanspeeder Samba Member
Joined: January 20, 2023 Posts: 33 Location: California
Posted: Mon Jun 26, 2023 4:24 pm Post subject: Recent Gas Smell |
Noticed a stronger than normal gas smell, outside of the van today after filling 3/4 of the tank at the station today.
Checked cap, the fill tube to the fuel filter and pump and back towards the lines up to charcoal filter. Any ideas on where to look or what to inspect?
Any help is much appreciated. |
space Samba Member
Posted: Mon Jun 26, 2023 5:17 pm Post subject: Re: Recent Gas Smell |
| Vanspeeder wrote: |
Your crossover tank line might be the culprit
Fill it next time and check for spills _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
do.dah Samba Member
Joined: August 27, 2015 Posts: 856 Location: Washington
Posted: Mon Jun 26, 2023 5:48 pm Post subject: Re: Recent Gas Smell |
Yeah, when you pull up to pump, make sure the ground is dry right behind fuel tank in center of van.
Fill up, wait a minute or so, and check under the van for fuel leaks.
This will now be your standard operating mode... |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1987 Location: Vancouver Island, BC
Posted: Mon Jun 26, 2023 7:34 pm Post subject: Re: Recent Gas Smell |
Check the evap tanks in the front wheel wells. I had a broken hose on the top (out of sight). Too see where the smell comes from exactly, you need to diag-nose  _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1217 Location: PNW — Washington
Posted: Tue Jun 27, 2023 8:09 am Post subject: Re: Recent Gas Smell |
| VicVan wrote: |
Check the evap tanks in the front wheel wells. I had a broken hose on the top (out of sight). Too see where the smell comes from exactly, you need to diag-nose  |
This… _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
VicVan Samba Member
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Tue Jun 27, 2023 5:42 pm Post subject: Re: Recent Gas Smell |
| I had a rodent chew a hole in one of my evap system lines. I found the leak by using a makeshift device to blow air into the gas tank and followed the hissing sound. |
Posted: Sat Jul 01, 2023 9:54 pm Post subject: Re: Recent Gas Smell |
| Thank you all, I will check the lines again. The evap tanks of the filler neck was my next guess. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4585 Location: ABQ NM USA.... Except when not
Posted: Sun Jul 02, 2023 7:10 am Post subject: Re: Recent Gas Smell |
A smoke machine is a great tool for this situation. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Tue Aug 08, 2023 12:52 pm Post subject: Re: Recent Gas Smell |
| Gas smell went away, added 5 more gallons and no smell again. I however want to start thinking of swapping the expansion tanks. |
