Selsk Samba Member
Posted: Tue Jan 23, 2024 12:21 pm Post subject: Failed smog today |
So my usual smog place ran a test that "he doesn't always run". But I failed the Gross creep or leak or something. He said it was because my charcoal canister is not hooked up on both sides. Although I know that it has never been connected the whole time I have owned this van. So can anyone give me a rundown on getting this connected again? Would you recommend getting a new canister if I do not know the life of the current one?
Cheers |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1186 Location: PNW — Washington
Posted: Tue Jan 23, 2024 1:01 pm Post subject: Re: Failed smog today |
Canister is likely OK. You will need to check the evap lines to the gas tank. The rubber grommets fail over time. A smoke test will reveal where the leaks are. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
Selsk Samba Member
Posted: Wed Jan 24, 2024 10:23 am Post subject: Re: Failed smog today |
Thanks Red Ryder. I will dig around. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2647 Location: Bay area CA
Posted: Wed Jan 24, 2024 10:47 am Post subject: Re: Failed smog today |
Selsk wrote: |
Cheers |
The test should pinch off the vent line that goes to the canister *before* the canister. On my van at least, there's a short amount of rubber hose between lengths of plastic hose to facilitate this. So the condition of the charcoal canister doesn't come into it.
There's a special gas cap that's fitted to the fuel filler, and the system is pressurised to a few PSI, and has to hold that for some minutes to pass the test. There are loads of places where air ("fumes") can leak - so if you haven't refreshed all your tank grommets, including the expansion tanks, for a few years it's time to do it. Refresh kits available from the usual suppliers.. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Wed Jan 24, 2024 7:42 pm Post subject: Re: Failed smog today |
The air cooled setup works differently from the setup for the WBXer engines. What do you have?
zerotofifty Samba Member
Posted: Wed Jan 24, 2024 8:35 pm Post subject: Re: Failed smog today |
On my 1986, the cannister hoses rotted off, up in the right rear wheel well area. Easy tix. Now my smog place does not have the correct gas cap adaptor, so he checks it off as unable to test and I pass with only a visual. I am in the greater San Fransisco Bay Area and thus have the full dyno smog test
Pass with flying colors four weeks ago.
I have a newish california catalyst, and newish O2 sender.
15 mph CO2 15.7%, O2 0.0% , HC 12 ppm, CO 0.01%, NO 1 ppm
25 mph CO2 15.8%, O2 0.0%, HC 7 ppm, CO 0.01%, NO 1 ppm
Cant get much cleaner than that!!!! _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Selsk Samba Member
Posted: Thu Jan 25, 2024 10:38 am Post subject: Re: Failed smog today |
Can anyone tell me the type/size of the hoses/lines coming out the bottom of the canister? |
VanWhalen Samba Member
Joined: June 02, 2016 Posts: 27 Location: East Bay, CA
Posted: Thu Jan 25, 2024 11:13 am Post subject: Re: Failed smog today |
8mm X 1mm (N 0201302) _________________ '84 Tintop
'85 Tintop
'69 Beetle |
tjet Samba Member
Posted: Thu Jan 25, 2024 12:27 pm Post subject: Re: Failed smog today |
Did you have the tank topped off? If there's a leak anywhere in the recovery system (canister, hoses, gas cap), the sniffer will get a whiff of raw gas. My '85 had a canister leak, but it only happened if I filled the gas tank up too far (raw gas smell). |
