Joined: January 06, 2024 Posts: 7 Location: Kennesaw, GA
Posted: Thu Apr 11, 2024 6:49 pm Post subject: 1980 Federal (not Cali) fuel injected double relay |
| I have been working on a 1980 Vanagon Federal, fuel injected 2.0. Was not running when I purchase it. First purchase was a Bentley manual and I have spent quite a bit of time with it. Before getting it started, I replaced gas tank, fuel pump, gas lines, fuel filter, injectors and seals, cold start valve, Temp 2 sensor, plugs, points, condenser, ignition wires. The van had sat for seven years without starting and was in mostly one piece with a large box of removed parts, all bad. I have run Bently ohm check on air flow and CPU terminals . Checking the double relay per Bentley, two of the checks showed 12 volts and one check showed .2 volts. The manual says all three must have voltage and I'm assuming that's 12 volts, so I'm thinking the relay is bad. I've found one for$400+. At present it runs poorly and when warms up, will stall and not restart until cooled off. I'm at wits end. First time with VW fuel injection. |
pathao Samba Member
Joined: November 01, 2012 Posts: 340 Location: Montreal, Canada
Posted: Thu Apr 11, 2024 8:06 pm Post subject: Re: 1980 Federal (not Cali) fuel injected double relay |
some people hack standard automotive relays
maybe read this
https://www.ratwell.com/technical/DoubleRelay.html _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
Posted: Fri Apr 12, 2024 7:46 am Post subject: Re: 1980 Federal (not Cali) fuel injected double relay |
| I had found that post, but, though I am decent at mechanics and wiring; I do not think I could accomplish making this. I have a friend who has been a lifelong VW mechanical shop owner and I'll see if he has a used one I can buy. My van is a very early '80 and the relay is silver. Thank you for the suggestion. All are welcome by this Vanagon newbie. |
steve244 Samba Member
Posted: Fri Apr 12, 2024 4:29 pm Post subject: Re: 1980 Federal (not Cali) fuel injected double relay |
| Steve, I answered your private message. Thank you so much! |
