1200 in need of some TLC
perello
perello is offline
PostPosted: Mon Jun 17, 2024 7:18 am    Post subject: 1200 in need of some TLC Reply with quote
this guy now is 21
and will inherit the car behind him as his first car...so I though is time to do some necessary repairs...I will be dropping randomly the work I do around it on here....
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jun 17, 2024 7:58 am    Post subject: Re: 1200 in need of some TLC Reply with quote
perello wrote:
this guy now is 21
On the car, or to the kid?
Wink
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
perello
perello is offline
PostPosted: Mon Jun 17, 2024 8:00 am    Post subject: Re: 1200 in need of some TLC Reply with quote
Wink
kid got TLC overdose already Wink
1974 German Thing
1978 Bug 1200
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Mon Jun 17, 2024 5:08 pm    Post subject: Re: 1200 in need of some TLC Reply with quote
I'm trying to figure out the free social security and first car at 21.
perello
perello is offline
PostPosted: Tue Jun 18, 2024 12:57 am    Post subject: Re: 1200 in need of some TLC Reply with quote
haha hint: look at the international section
anyway first hing was to remove the old rusted half floor pans
and make obvious the different rusted spots
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Wed Jun 19, 2024 12:47 am    Post subject: Re: 1200 in need of some TLC Reply with quote
so, after cutting out the rust, slowly welding back heater channels
and wheel wells
[/url]
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Thu Jun 20, 2024 1:04 am    Post subject: Re: 1200 in need of some TLC Reply with quote
some more welding, the patch parts available in the market are not that great....also I dont fully understand the inner of this section...
1974 German Thing
1978 Bug 1200
jarmchairpilot
jarmchairpilot is offline
PostPosted: Fri Jun 21, 2024 9:48 am    Post subject: Re: 1200 in need of some TLC Reply with quote
Great, come and do mine, I've been putting it off for ten years as I drive my 72 standard daily!
perello
perello is offline
PostPosted: Tue Jun 25, 2024 1:50 am    Post subject: Re: 1200 in need of some TLC Reply with quote
hahaah on my way!
i jumped to check the front, removed the spindles, lower ball joint dust cover was ruined so time to replace
while there checked if spindles were straight
1974 German Thing
1978 Bug 1200
VWNOS.com
heimlich is offline
PostPosted: Tue Jun 25, 2024 9:02 am    Post subject: Re: 1200 in need of some TLC Reply with quote
perello wrote:
What is going on in that picture? Looks like you have stuff held together with a car jack.
perello
perello is offline
PostPosted: Tue Jun 25, 2024 10:19 am    Post subject: Re: 1200 in need of some TLC Reply with quote
1974 German Thing
1978 Bug 1200
VWNOS.com
heimlich is offline
PostPosted: Tue Jun 25, 2024 10:22 am    Post subject: Re: 1200 in need of some TLC Reply with quote
You use that before you replace the ball joint or after?
perello
perello is offline
PostPosted: Tue Jun 25, 2024 10:28 am    Post subject: Re: 1200 in need of some TLC Reply with quote
to get the spindle off and then back in
1974 German Thing
1978 Bug 1200
VWNOS.com
heimlich is offline
PostPosted: Tue Jun 25, 2024 11:10 am    Post subject: Re: 1200 in need of some TLC Reply with quote
OK. I understand now. I always replaced the ball joint with everything attached to the car. It looks like you are going through everything to make it tip top shape.
perello
perello is offline
PostPosted: Wed Jun 26, 2024 12:51 am    Post subject: Re: 1200 in need of some TLC Reply with quote
I was talking about replacing the rubber dust cover
to replace the ball joint I need to remove the torsion arm and use a 20 ton hidraulic press...how you do that attached to the car?
some candy
1974 German Thing
1978 Bug 1200
VWNOS.com
heimlich is offline
PostPosted: Wed Jun 26, 2024 6:31 am    Post subject: Re: 1200 in need of some TLC Reply with quote
I have a ball joint tool. There are cups that fit over the ball joint.
Here's a newly made tool. I have one specific to the VW one now but you can get the general idea from it.
perello
perello is offline
PostPosted: Tue Jul 23, 2024 3:26 am    Post subject: Re: 1200 in need of some TLC Reply with quote
some progress, I did remove the transaxle to clean and replace boots, i like the seamless type
Taking out axle bearings
also fitted firewall tarboard, guess its the jbugs thick version...I did all possible mistakes
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Tue Sep 03, 2024 4:02 am    Post subject: Re: 1200 in need of some TLC Reply with quote
the work is going on, I am replacing the front beam... too rusty, and took the opportunity to
check the steering box
The roller was pitted so I replaced with a new one
and cleaned all parts
thanks to the incredible Tom thread on type 3 section, the resto end up looking good
1974 German Thing
1978 Bug 1200
VWNOS.com
heimlich is offline
PostPosted: Tue Sep 03, 2024 8:14 am    Post subject: Re: 1200 in need of some TLC Reply with quote
That roller is definitely pitted. Where'd you get the replacement?
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Thu Sep 05, 2024 8:28 pm    Post subject: Re: 1200 in need of some TLC Reply with quote
looks like you got the right tools!
proceed Smile
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
