License Plate Door Prop
mtnhome Premium Member
mtnhome is offline
PostPosted: Wed Jul 17, 2024 1:59 pm    Post subject: License Plate Door Prop Reply with quote
I just added this to another thread but thought more people might want to see it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=789127 You'll see Samba member VeeDubn had a very similar idea.
I designed this to be 3d printed and a piece of 1/2" pvc pipe used as the rod. Cut to length depending on where you decide to mount this.
It is mounted with 3m HD Mounting tape. Mainly make sure it won't interfere with the coolant reservoir. Either above or below the reservoir cap.
STL files are here: https://www.thingiverse.com/thing:6699968
'84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight=
djkeev
djkeev is offline
PostPosted: Wed Jul 17, 2024 2:12 pm    Post subject: Re: License Plate Door Prop Reply with quote
Whoa!
Nice!
Mine is low tech old school.......a cut off paint stick, it slips into the hold door closed spring at the top of the door.
Ghia
Vanagon
Beetle
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Wed Jul 17, 2024 2:42 pm    Post subject: Re: License Plate Door Prop Reply with quote
mtnhome wrote:
....It is mounted with 3m HD Mounting tape. Mainly make sure it won't interfere with the coolant reservoir. Either above or below the reservoir cap....
Don't forget about using the oil filler, may want to mount to the extreme right (folding to the left) or extreme left (folding to the right) Wink
Currently:
All that's needed for evil to prevail is for good people to do nothing.
Sodo
Sodo is offline
PostPosted: Wed Jul 17, 2024 2:50 pm    Post subject: Re: License Plate Door Prop Reply with quote
You can kinda tell if a van is an oil-drinker or a coolant-drinker by the chosen location of the door prop Wink
One that fits down in the hinge area and doesn't block access to either fluid would be ideal I think.
Careful with adhesives that become gooey in the heat. And getting those hinge screws out can be a problem.
License pl;ate screws are pretty easy but are far from the hinge.
Maybe drilling a lower license plate mount hole.
What about the coolant reservoir screws - do they get stuck too?
Bolt-on, no mods no drill is a crowd pleaser for vintage vehicles.
....KTMs, GasGas, SPOT mtb
mtnhome is offline
PostPosted: Wed Jul 17, 2024 2:57 pm    Post subject: Re: License Plate Door Prop Reply with quote
The ball and socket pivot can be used in a few ways.
It's pretty customizable.
mtnhome is offline
PostPosted: Wed Jul 17, 2024 3:15 pm    Post subject: Re: License Plate Door Prop Reply with quote
The tape is made for outdoor, in the sun use. I've got other stuff mounted in the engine compartment with this tape.
Because this was designed in pieces, you can pretty much make it work for your own use.
None of the screws are blocked by the location I'm using.
jimf909
jimf909 is offline
PostPosted: Wed Jul 17, 2024 3:46 pm    Post subject: Re: License Plate Door Prop Reply with quote
Neato.
Is that sound deadening material on the door? A heat barrier? What is it and why?
- Jim
Butcher wrote:
Guilty as charged.
mtnhome is offline
PostPosted: Wed Jul 17, 2024 4:04 pm    Post subject: Re: License Plate Door Prop Reply with quote
jimf909 wrote:
Neato.
Sound deadening. After I did my conversion, I was getting a strange vibration noise and finally tracked it to the door. First tried making the spring tighter, then added some foam tape to eliminate any play but it seemed to have a resonance at some speeds/rpm’s so threw some pieces of Kilmat on and noise gone. I must have had the perfect setup to generate that noise.
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Wed Jul 17, 2024 6:15 pm    Post subject: Re: License Plate Door Prop Reply with quote
i guess this is for people who don't know how to use the oil cap?
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
kamzcab86
kamzcab86 is offline
PostPosted: Wed Jul 17, 2024 6:47 pm    Post subject: Re: License Plate Door Prop Reply with quote
Or coolant cap.
They're clever ideas to be sure (and a Thumbs Up for ingenuity), but "props" are basically built into the vans from the factory.
P.S. The black stuff is rubber from the Stant pressure cap seal.
~Kamz Anxious
2016 Golf GTI S
djkeev
djkeev is offline
PostPosted: Wed Jul 17, 2024 7:13 pm    Post subject: Re: License Plate Door Prop Reply with quote
kamzcab86 wrote:
Or coolant cap.
[pics]
That trick will come back and bite you Kam.
I used to do that before the paint stick.
The cap slipped, fell through a crevice and took me 20 minutes to locate and retrieve, NEVER AGAIN!
Ghia
Vanagon
Beetle
zerotofifty
zerotofifty is offline
PostPosted: Wed Jul 17, 2024 7:14 pm    Post subject: Re: License Plate Door Prop Reply with quote
kamzcab86 wrote:
Or coolant cap.
[pics]
very pretty blue color. Mine is all faded.
kamzcab86
PostPosted: Wed Jul 17, 2024 7:57 pm    Post subject: Re: License Plate Door Prop Reply with quote
djkeev wrote:
kamzcab86 wrote:
Or coolant cap.
Fourteen and a half years, not a problem. To each their own. ¯\_(ツ)_/¯
Thanks. Well-cared-for Orly Blue Metallic.
~Kamz Anxious
2016 Golf GTI S
ppiche
ppiche is offline
PostPosted: Wed Jul 17, 2024 8:26 pm    Post subject: Re: License Plate Door Prop Reply with quote
Well me too I always use the caps, but djkeev is right, what a fail the day we drop it in a hole Shocked
do.dah
do.dah is offline
PostPosted: Thu Jul 18, 2024 9:33 pm    Post subject: Re: License Plate Door Prop Reply with quote
My van has, what I'm very sure of, a factory rubber kinda gasket(?)/filler(?)/apron(?) attached to the underside of the top of the bumper and seals up to the body. Stuff doesn't drop into the bumper.
Jake59
Jake59 is offline
PostPosted: Sun Aug 18, 2024 12:22 pm    Post subject: Re: License Plate Door Prop Reply with quote
I have always been a "water cap" or "oil cap" finda guy, but the other day I found a new even simpler solution. Now I didn't know if this is just a fluke for me and the manner in which my "Twin Peaks" bumper are mounted but I'll take the win.
The pull tab just hooks on the bumper just over the 2" receiver hitch. Granted if I have our bike rack in the hitch this will not work and I'm back to the "filler cap" solution.
Curent ride: 87 2WD Westy, 2012 Jetta Sportwagon 2.5S
Past Rides: 62 (23 window) Bus, 64 Ghai convertable, 68 single cab, 72 Super Bettle, 78 Bay window Bus, 84 GTI.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Aug 18, 2024 1:07 pm    Post subject: Re: License Plate Door Prop Reply with quote
I use a wooden block (with an idiot string):
File these under: Cats, ways to skin.
Jake59
Jake59 is offline
PostPosted: Sun Aug 18, 2024 3:13 pm    Post subject: Re: License Plate Door Prop Reply with quote
I love your oil change schedule location. Again simple wins!
DanHoug
DanHoug is offline
PostPosted: Sun Aug 18, 2024 6:09 pm    Post subject: Re: License Plate Door Prop Reply with quote
putting the Westy access doors in back is super cool! i'm lookin' at YOU trailer lights!! but they seem happy for now on an umbilical stuffed in the plate space.
-dan
www.thefixitworkshop.com
mtnhome is offline
PostPosted: Sun Aug 18, 2024 7:18 pm    Post subject: Re: License Plate Door Prop Reply with quote
The hook-up box is for an onboard air compressor mounted behind the taillight.
Made a thing to keep the trailer lights wire in place.
