Rear Speaker box - 1968 VW Bug
Dottie1968Bug
Dottie1968Bug is offline
PostPosted: Sun Aug 25, 2024 7:22 pm    Post subject: Rear Speaker box - 1968 VW Bug Reply with quote
Just got a 1968 VW Beetle and working a rear speaker box for two 6x9 and one 8 inch sub. We have seen a couple builds with a "flat" box across the top, but wanted to try something different.
Hopefully this helps someone with some ideas if your planning on building a box.
Chip26
Chip26 is offline
PostPosted: Sun Aug 25, 2024 8:54 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
That could be useful for anyone planning a similar setup.
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Aug 26, 2024 8:02 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
That looks so ’80’s! I love it.
I went a different route with speakers in the doors, speakers in a custom box in the rear and 2 12” subs sunk into the rear seat wells.
It hits pretty hard and will shake my kidneys but going down the road I still have to crank it up to hear it above the sound of my 2276.
Rock on!
Apparently, I need to load some more pictures to the site.
Volkswagen!
(Compression 8.7:1)
runamoc Premium Member
runamoc is offline
PostPosted: Mon Aug 26, 2024 5:59 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
back in the 80's Pep Boys was into selling a lot of different stuff. They were selling this...matching carpets Wink and fit right in ($40). The speakers had neon rings with a controller that would make the neon 'flash' to the music. Thought of connecting the rings up as an interior light but never done anything with them.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
bsairhead
bsairhead is offline
PostPosted: Mon Aug 26, 2024 6:34 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Not an automotive audio fife, don't you want some venting?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Aug 26, 2024 6:38 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
I use a bluetooth speaker and my smartphone.
This way I can take it with me when camping before a show.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Multi69s
Multi69s is offline
PostPosted: Mon Aug 26, 2024 6:40 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Dottie, how are you holding the box in? in a bad wreck it could be a missile. A piece of all thread through the bottom of the box and through the body would work.
Great looking though
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
54bug
54bug is offline
PostPosted: Tue Aug 27, 2024 5:36 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Hi Dottie1968Bug
A quick summary of my experience, hope it helps with your project
I assembled a 1969 beetle from the ground up, and created a perfect stereo, with modified suspension, engine, electrical system, body mods, etc. The story is about all the work and the Stereo.
Your back seat box looks good, creating a correct volume sub box with enough insulation, and the need for sealed boxes for your 6X9's are open questions. I used a Retro sound powered sub under the front seat, and 4 sets of speakers. The stereo sounds amazing, mainly when parked.
Keep in mind the amount of road noise, and how your music will sound at highway speed. You can turn it up, but I've found I leave the stereo off, and listen to the car on the highway.
Building the stereo was an interesting exercise, but in retrospect, I should have gone simpler.
Scott
runamoc is offline
PostPosted: Tue Aug 27, 2024 7:13 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
A buddy was going to spend 'extra' for a car stereo that had less than 1% THD (Total Harmonic Distortion) told him to save his money because a car stereo, playing while going down the hi-way, could have 10%THD and you couldn't tell it.
anthax
anthax is offline
PostPosted: Thu Aug 29, 2024 12:03 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Looks good.
I might do something similar. I want to replace the thing the previous owner made and put in. It's way too heavy and ill fitting.
Thanks for the tips! Smile
Dottie1968Bug
PostPosted: Sun Sep 15, 2024 3:09 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Thanks for the inputs everyone! It sounds really good, and probably over kill in a small bug but its been a fun project. In addition to the rear speaker + subs, I have played with two 5.25 speakers hidden as back seat "pillows".
So far super happy with how these complement the car, it makes everything sound a little fuller - not just like you have your back to the sound.
Dottie1968Bug
PostPosted: Sun Sep 15, 2024 3:12 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Yes, I did touch base with a handful of local audio shops with the designs and had them check my work once I was done. Everything does have enough venting or space to prevent things from heating up!
Dottie1968Bug
PostPosted: Sun Sep 15, 2024 3:15 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
I will be running a connection point to the rear seat belt attachment points - not ideal to link into the rear seatbelt bolt but I am ok with it bc this is not a daily driver + no one will be sitting back there.
jeff68
jeff68 is offline
PostPosted: Wed Sep 18, 2024 5:30 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Nice Work Dottie! I've got all the materials cut up for a removeable behind the seat speaker / sub box with an integrated amp as well. Once i assemble the box I was going to cover it with the stock seat upholstery material as well. I love the "Pillows" too.
Jeff
Max Welton
Max Welton is offline
PostPosted: Mon Sep 15, 2025 12:55 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Nicely done! Is anyone aware of bluetooth speakers that look like these?
Max
1967 Type-3 Fastback
jeffrey8164
PostPosted: Mon Sep 15, 2025 2:53 pm    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Nice work! I love those.
Makes the back seat look like a sofa.
Volkswagen!
(Compression 8.7:1)
CoastalBug
CoastalBug is offline
PostPosted: Mon Sep 22, 2025 1:36 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
jeffrey8164 wrote:
What size were you able to fit in the door? Looks about a 6"? Did it have to be a shallow mount?
Chris - 1968 Beetle Sedan, a book, and a lot of determination.
CoastalBug
PostPosted: Mon Sep 22, 2025 1:41 am    Post subject: Re: Rear Speaker box - 1968 VW Bug Reply with quote
Are the black mounting rings on the ends 3d printed, or ready made off the shelf?
