Zamper1978 Samba Member
Posted: Tue Oct 01, 2024 7:38 am Post subject: Dashboard lights off after short and smell of cables |
Hello all,
i have a custom switch on my T2 dashboard next to the headlight switch that i installed extra led lights . i believe created a short circuit whe i turned it on last time, lot's of smell and smoke. i guess a cable become loss on the back of the dash and touch each other because both switches are close enough. Lots of smell like cable or even relay mechanism i would say (like capacitors or mosfet smell when the board somewhere get's short) . Now i have not any more lights in the dash except the indicator lights (battery etc) i mean i cannot dim it up or down is just dead and if i drive in the night i see nothing.
I do not want to remove the dash on my own, i tried to make some photos from the back, can somebody advise if something doesn't look normal?
The switch on the bottom is the headlight switch and the other on the top is the custom for 2 extra lights in the front (they used to play ok together)
How many cables should the dimmer relay have?
This week i will try to remove the headlight switch to see what happened.
[/img] |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2720 Location: Ocean Beach - San Diego
Posted: Tue Oct 01, 2024 8:28 am Post subject: Re: Dashboard lights off after short and smell of cables |
Other people who are a lot smarter than me with electricity will jump in.
My one suggestion: disconnect the negative lead on the battery before touching anything else! _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
Posted: Tue Oct 01, 2024 8:50 am Post subject: Re: Dashboard lights off after short and smell of cables |
thank you for your reply, bus at the moment is parked for some time so yes the battery is already disconnected. Though i have fixed at my own any battery drain i had before and would kill the battery, it was the CD Player and a custom clock that i have in my dashboard (they where consuming about 1.5A/h!) |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3625 Location: San Diego (Encinitas)
Posted: Tue Oct 01, 2024 9:01 am Post subject: Re: Dashboard lights off after short and smell of cables |
You most likely burnt up the rheostat in your headlight switch. Measure the voltage at headlight switch terminal 58b. Lack of voltage confirms switch failure.
I would remove your added switch and check everything carefully before replacing the headlight switch. I recommend adding 1" lengths of 1/4" heatshrink tubing over all bare switch wire terminals. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1910 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Tue Oct 01, 2024 9:12 am Post subject: Re: Dashboard lights off after short and smell of cables |
listen to telford.
when you say remove the dash, do you mean remove the instrument cluster? cause that’s pretty easy to do (pull the fresh-air/heater levers, four screws, and the speedo cable), and provides easy access to switches and wires. at least it does on my ‘78. you don’t say the year of your bus. it’d be a good idea to post it in the signature section. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8576 Location: Las Vegas
Posted: Tue Oct 01, 2024 9:29 am Post subject: Re: Dashboard lights off after short and smell of cables |
I did this recently. Telford is correct, get a new headlight switch. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4094 Location: Seattle, WA
Posted: Tue Oct 01, 2024 10:53 am Post subject: Re: Dashboard lights off after short and smell of cables |
Dash lighting will still work with a dead rheostat element, just turn the knob all the way (I forget which direction) and the rheostat will be bypassed for 100% voltage to the dash lights. Also, there's no insulation around the rheostat coil, so burning it up will not likely produce much smoke or smell, at least not from that part of the headlight switch. It seems none of the wires attached to light switch or dimmer relay are fused, I would be checking those wires for accidents, especially gray/red wire from terminal 58b on light switch, which feeds the dash lights.
Dimmer relay has 4 wires attached: white, yellow, white/black (fat) and brown/white (thin). _________________ '67 bug: seized by the authorities
Posted: Tue Oct 01, 2024 11:21 am Post subject: Re: Dashboard lights off after short and smell of cables |
kreemoweet wrote: |
Dimmer relay has 4 wires attached: white, yellow, white/black (fat) and brown/white (thin). |
You are correct, now that i've googled what's inside a relay there is no capacitors or mosfets that i thought they make this "short circuit smell" from my experienced nose when i've shorted by mistake a circuit board in the past. Must be a cable that was burned all the way down to the dimmer or to the relay for the dimmer switch (those are seperate stuff to control the dim or even the dashboard light?) and then the dashboard light gone off or because of the dimmer burned there is no light at at all.
This took 10 seconds to realise when i just turn the key on and directly i turn it off before even start the engine because of the smell/smoke. Of course i've tried several times to rotate the switch but there will be no light at all. Could it also be that the bulb inside the dashboard got damaged because of this short circuit? I wish it was easy to access the dashboard but i am a little bit stressed to remove it all the way off, i guess only this will show what is happening behind.
But from the pictures i took above i do not see any burned/disconnected cable, this is very strange.
I want to ask you, there are two different relays for the dashboard light? For example .. this one behind the switch is also a relay? ( i see 3 cables only) and then there is also another relay to control this?
Thanks for your suggestions. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Tue Oct 01, 2024 12:36 pm Post subject: Re: Dashboard lights off after short and smell of cables |
The wire winding for the rheostat function can break, get unwound, and short out other connections inside the switch.
_________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Tue Oct 01, 2024 1:27 pm Post subject: Re: Dashboard lights off after short and smell of cables |
KTPhil wrote: |
i think this should be the problem. After the short circuit accident i could feel the metal wire in the back of the switch to become broken apart with touching it with my finger. So maybe it melt off when the short happened. It looks like the headlight switch will need replacement. Can you tell me if there is also the other relay that i should check or normally should be the unit of the switch to be replaced? |
