smokeydogvol Samba Member
Joined: November 04, 2024 Posts: 11 Location: Knoxville, TN
Posted: Sat Nov 16, 2024 6:32 pm Post subject: Throttle Cable Linkage Popping Off |
My throttle cable has the ball socket linkage and popped off twice this afternoon going down the road. What do I need to do to secure this? There is no way to tighten it. Is it worn out and I just need to replace or is there way to fix it?
Obviously I do not want to venture out again until I figure this out.
Thank you!
[/img] |
Heiferman Samba Member
Joined: February 28, 2024 Posts: 291 Location: Georgia, USA
Posted: Sun Nov 17, 2024 6:13 pm Post subject: Re: Throttle Cable Linkage Popping Off |
Usually those will have a clip like this
https://mossmotors.com/072-029-retaining-clip-accelerator-cable
There are several sizes available from retailers but when is place it would look like this:
You should be able to get one with the right diameter. _________________ - 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance |
Posted: Sun Nov 17, 2024 7:46 pm Post subject: Re: Throttle Cable Linkage Popping Off |
Thank you for the reply! I may just change out the connection type altogether. Seems like this type of connection is less common and a silly design in my opinion. |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1102 Location: Calgary, AB
Posted: Tue Nov 19, 2024 7:25 pm Post subject: Re: Throttle Cable Linkage Popping Off |
The ball / socket can wear out and pop off. Those clips posted above are correct, but the ball should still hold reasonably tight with out it.
You can also get these joints from Gene Berg:
http://www.geneberg.com/product_info.php?cPath=8_234&products_id=842
I ordered some for my Weber carbs a few years back. Nice quality and the rubber boot keeps the ball clean and greased so the linkage always moves smooth.
You’d have to confirm this size to your existing rod, or just replace all the parts. Hard to beat the price. |
Posted: Thu Dec 12, 2024 10:01 am Post subject: Re: Throttle Cable Linkage Popping Off |
CanStan wrote: |
Thank you so much! I appreciate your response! |
