seatown7 Samba Member
Posted: Mon Nov 25, 2024 12:49 pm Post subject: Updated Theft Advice? |
Greetings,
I'm shopping for a Westy and think I've found "The One." It has no theft prevention installed which concerns me.
I checked the FAQ pages for theft deterrence ideas and am grateful for the advice listed there....BUT...
I observed that most of it was generously offered in 2008!
Surely there have been new developments in van theft prevention since then.
Could we please revisit what y'all have found in the last 16 years?
I'm definitely getting a kill switch installed, will likely have an Air Tag hidden, but how about anti prowl measures? Anything that alerts you to open doors etc?
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8381 Location: NE MN (tinyurl.com/dhaaverslocation)
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Nov 25, 2024 1:14 pm Post subject: Re: Updated Theft Advice? |
Most van thefts I've read about in the last few years come from vans parked on streets overnight in less desirable or high density areas. If you have a driveway or off street parking, odds are far less your van will be bothered. It really depends on your living situation in my opinion. _________________ 89 Westy 2.1 Auto |
zerotofifty Samba Member
Posted: Mon Nov 25, 2024 2:17 pm Post subject: Re: Updated Theft Advice? |
Now days a manual shift transmission serves as a theft deterrent. Crooks are more lame, perhaps more violent, but certainly more lame these days.
You can add kill switches for fuel or ignition, loud alarms, all the standard stuff.
some folks may want to try a parking violation type locking "boot" attached to a wheel to disable the vehicle from driving. |
tdivan82  Samba Member
Joined: September 17, 2023 Posts: 248 Location: Virginia
Posted: Mon Nov 25, 2024 2:32 pm Post subject: Re: Updated Theft Advice? |
These vans are typically stolen by someone who breaks in and "hotwires" the ignition switch to drive off. It's pretty simple to do on these vintage vehicles, and the thief knows there's no alarm. It's frequently bums and drug addicts who steal them to live in, not some high-tech Mission Impossible heist.
IMO the two most effective methods are a hidden kill switch that prevents the engine from starting, and a pedal lock. Steering wheel locks like "The Club" are ineffective. GPS trackers help you locate it after it's stolen, but are not preventative. There's really nothing you can do to prevent someone from gaining access to the interior, so focus your efforts on preventing an unauthorized drive-off.
The pedal lock I like is this one, which prevents a thief from operating the brake and clutch pedals.
The combination of no-start (kill switch), and no pedals (pedal lock), will deter pretty much every casual thief out there. _________________ - George
'82 Westy TDI (ahu)
'96 Passat TDI |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4618 Location: United States, Iowa
Posted: Mon Nov 25, 2024 2:47 pm Post subject: Re: Updated Theft Advice? |
Take the steering wheel with you. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
do.dah Samba Member
Joined: August 27, 2015 Posts: 795 Location: Washington
Posted: Mon Nov 25, 2024 2:50 pm Post subject: Re: Updated Theft Advice? |
You should have both a hidden deterrent and a HIGHLY visible deterrent.
It is a well know fact that a "club" is easily bypassed, but it is VERY visible deterrent.
I have a hidden kill switch/alarm, a bright yellow visible peddle lock that has a "dick" sticking up between the driver' legs, and a bright yellow locking device that slides onto the e-brake and locks onto the shifter.
I just hope that the visuals are enough to make a scumbag choose something else.... |
kourt Samba Member
Joined: August 13, 2013 Posts: 2309 Location: Austin, TX
Posted: Mon Nov 25, 2024 3:05 pm Post subject: Re: Updated Theft Advice? |
As others have said, you will not succeed in preventing access to the van--it's just too easy to break into these vans.
GPS locator to find a stolen Vanagon is a thread that has been continuously updated since 2013 with good advice for tracking your van.
When someone's van gets stolen, the first questions everyone asks are:
1. did you have a kill switch installed, and did you use it?
2. did you have a tracker installed, and did you use it?
I see you are in Seattle. I would never own a van there without a killswitch and a tracker.
kourt |
DeLvxe Samba Member
Joined: January 08, 2019 Posts: 138 Location: Seattle
Posted: Mon Nov 25, 2024 3:28 pm Post subject: Re: Updated Theft Advice? |
Seattle dweller here! Never had a problem with vandals / thieves here, but I have a tracker installed. I recommend https://gpsandtrack.com/car_tracker/ as an affordable options. I have plans to install a kill switch, but it is somewhere down the list -- probably below fixing the power mirrors but above dealing with some paint chips. _________________ 1991 manual camper with EJ25 |
Mikesarge Samba Member
Posted: Mon Nov 25, 2024 3:42 pm Post subject: Re: Updated Theft Advice? |
I'm in inner SE Portland, and over the years I've had several neighbors have their vanagons stolen. Mine has not been stolen yet. Lately, it's been parked off-street, which obviates many of the issues with street-parked vans.
That being said, I have a kill switch (hidden) and a steering wheel boot (I leave that unlocked, but it is visibly installed).
My theory is the steering wheel boot signals that it's more work than it's worth, and the kill switch actually makes it more work than it's worth. So far so good!
As I've offered on threads like this in the past: I'm more than happy to help other vanagon owners in the area install a kill switch if they want a hand, just send me a message. _________________ 1986 Syncro westfauxlia EJ22
1980 911 SC 3.1
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79445 Location: Sneaking up behind you
Posted: Mon Nov 25, 2024 3:43 pm Post subject: Re: Updated Theft Advice? |
If they want it, they'll take it and there's very little you can do other than having it in a locked garage.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
the_benjamin_effect Samba Member
Joined: May 31, 2010 Posts: 323 Location: Gateway to the North Cascades, Washington State
Posted: Mon Nov 25, 2024 4:08 pm Post subject: Re: Updated Theft Advice? |
MY $0.02...
I think a hidden kill switch that disables the ignition circuit is the best solution, where the motor will still crank, but not ignite. IMO the thief will attempt to crank the engine once or twice and be done with it after making all that noise. Most likely, they want an easy target and a quick getaway. If the engine cranks and does not ignite, they most likely to believe the vehicle is broken/inoperative and move on...
But I'm no thief, so I have no idea what goes on in those tweaker heads...
Just my humble opinion. _________________ -1967 Sundial Camper 1914cc "Sunny"
-1978 Deluxe Westfalia Jake Raby built PowerStroke 2109cc "Westy"
-1987 SYNCRO Westfalia GoWesty 2400cc "Ruby"
-2000 Subaru Impreza Sport EJ22 ¼ million miles "Trusty"
International Association of Machinists and Aerospace Workers. I.A.M. 751
International Brotherhood of Naval Flight Engineers. I.B.N.F.E. LOCAL 8251
U.S. NAVY Retired; Senior Chief Flight Engineer, P-3 Orion and EP-3E Aries II
U.S.S. Carl Vinson, VFA-22, VQ-2, VQ-1, VP-30 |
fxr Samba Member
Joined: December 07, 2014 Posts: 2640 Location: Bay area CA
Posted: Mon Nov 25, 2024 4:30 pm Post subject: Re: Updated Theft Advice? |
I'm extremely happy with this kill-switch solution. The huge advantage is that it "arms" as soon as you take the key out, so you don't have to remember to "do something" each time you leave the van.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8882643#8882643
_________________ Jim Crowther
Vespa GTS 300 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17131 Location: Brookeville, MD
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1178 Location: PNW — Washington
Posted: Mon Nov 25, 2024 6:53 pm Post subject: Re: Updated Theft Advice? |
Glenn wrote: |
If they want it, they'll take it and there's very little you can do other than having it in a locked garage. |
We like a “belts and suspenders” approach. Scarlett is equipped with a kill switch, and is stored in a locked garage. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
Glenn  Mr. 010
Posted: Mon Nov 25, 2024 7:44 pm Post subject: Re: Updated Theft Advice? |
Just remove the distributor rotor. _________________ Glenn
Member #1009
#BlueSquare
Xevin  Samba Member
Posted: Mon Nov 25, 2024 7:50 pm Post subject: Re: Updated Theft Advice? |
Glenn wrote: |
Just remove the distributor rotor. |
Super easy and discreet in a Split or bay. Not so easy and discreet in a Vanagon.
Sure if Vanagon is going to be parked for a long time _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 8245 Location: Westfalia, Earth
Posted: Mon Nov 25, 2024 8:00 pm Post subject: Re: Updated Theft Advice? |
All I hope is thieves are too dumb to use Google and learn how to steal my rig with these how-to threads. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman
Klister Samba Member
Joined: March 06, 2018 Posts: 257 Location: Washington
Posted: Mon Nov 25, 2024 8:29 pm Post subject: Re: Updated Theft Advice? |
Quote: |
Seriously doubt we have to worry about tow truck snatches. But it seems tweakers are a real concern.
I have a kill switch and tracker. |
Yep - same here. The way to go |
