Clutches?
JBeetles
JBeetles is offline
PostPosted: Mon Dec 09, 2024 5:02 pm    Post subject: Clutches? Reply with quote
Hey all -
Quick question - what would be a good clutch for a healthy 2276 Beetle (180-200 HP) with a transaxle built to match? Someone installed a weak empi clutch and now it floats at higher rpms. Any advice would be much appreciated. Thanks in advance.
Dale M.
Dale M. is offline
PostPosted: Mon Dec 09, 2024 5:18 pm    Post subject: Re: Clutches? Reply with quote
At least Kennedy Stage I, if you really like a positive hook up go for something a little more.......
https://www.kennedyeng.com/clutches
74 Thing
74 Thing is offline
PostPosted: Mon Dec 09, 2024 8:06 pm    Post subject: Re: Clutches? Reply with quote
Stage 1 Kennedy pressure plate is for approx 175 lb ft of torque and Stage 2 is for approx 210 lb ft using an organic clutch disc.
There are two parts a pressure plate and a clutch disc.
BFB
BFB is offline
PostPosted: Mon Dec 09, 2024 8:19 pm    Post subject: Re: Clutches? Reply with quote
CB’s dual friction disks are nice too. Smoother than a puck and better grip than a stock type disk
Most experts aren't.
richparker
richparker is offline
PostPosted: Tue Dec 10, 2024 7:01 am    Post subject: Re: Clutches? Reply with quote
I have 2 motors later to Kennedy state 1 clutches. Best thing I ever did!
Love to know more about this 200 hp 2276. Like how did you come up with that number?
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Dec 10, 2024 7:10 am    Post subject: Re: Clutches? Reply with quote
KEP Stage 1 with a dual friction disc, engine is a 2180 w/ a Berg 5, ZF and 100mm arm. Will easily smoke both rear tires.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
runamoc Premium Member
runamoc is offline
PostPosted: Tue Dec 10, 2024 8:33 am    Post subject: Re: Clutches? Reply with quote
The best tool for finding out how well your clutch/press plate works is a transaxle input shaft with a socket welded on the end. Insert the spline end of the input shaft into the clutch and use a torque wrench to turn the socket. When the clutch slips that's how many ft/lbs of torque that combination can handle.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
chrisflstf
chrisflstf is offline
PostPosted: Tue Dec 10, 2024 10:03 am    Post subject: Re: Clutches? Reply with quote
I have a stage 1 kp with a factory long arm. You can depress it with your hand very easy.
Leverage is your friend
