scott woodward Samba Member
Posted: Thu Dec 12, 2024 9:45 am Post subject: 34-pic3 carb popping |
I got a 34 – pick three carburetor on my 1776. I’ve got everything adjusted starts right up, but there’s a consistent popping out of the carburetor, needle valve? I’ve taken it apart and cleaned everything and blown out the ports put it back on and readjust it and I get the same thing. Any ideas? Thanks guys. _________________ Peace! |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 944 Location: Moreno Valley
Posted: Thu Dec 12, 2024 9:54 am Post subject: Re: 34-pic3 carb popping |
| are the valves adjusted right ? |
aquifer  Samba Member
Joined: August 30, 2021 Posts: 452 Location: Nebraska
Posted: Thu Dec 12, 2024 10:08 am Post subject: Re: 34-pic3 carb popping |
Like a backfire? Check the valve adjustments as suggested, and make sure your timing is correct too. _________________ Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date. Java Green.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Original brown rubber floor mats for a '67
Original gazelle seat upholstery for a ‘67 |
Posted: Thu Dec 12, 2024 10:28 am Post subject: Re: 34-pic3 carb popping |
Time is correct and valves adjustments, correct but I’m gonna double check, thank you _________________ Peace! |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16749 Location: North Florida, USA
Posted: Thu Dec 12, 2024 10:49 am Post subject: Re: 34-pic3 carb popping |
| scott woodward wrote: |
| Time is correct and valves adjustments, correct but I’m gonna double check, thank you |
Please confirm how you have both set? Details/numbers/method pls.
Spark igniting the intake mixture... valve stuck open or incorrect ignition timing? _________________ AshMan40
rcooled Samba Member
Joined: September 20, 2008 Posts: 2842 Location: Santa Cruz, CA
Posted: Thu Dec 12, 2024 12:00 pm Post subject: Re: 34-pic3 carb popping |
| ...but there’s a consistent popping out of the carburetor |
Is the carb an original German SOLEX, or some aftermarket clone? Did this issue start suddenly, or has it always been occurring to some degree? Is it happening only at idle, or throughout the entire RPM range?
Does the car still drive normally with the usual amount of power? Has it always run pretty well before now? Have the valves always been adjusted to spec, or is the motor's maintenance history unknown? Do you know many miles are on it?
A cracked or burnt intake valve (though not very likely if always properly adjusted), as well as an overly-lean fuel mixture can cause the symptoms you describe. A 1776 will be inhaling more air than a 1600 and the carb may require different jetting to compensate. What size jets (main, idle & air correction) are in the carb now?
The level of fuel in the carb's float bowl can play a role here too. With the carb top and gasket removed, the fuel level should be about 3/4" down from the lip of the bowl with the float in place. The level is set by adjusting the thickness of the washer(s) under the inlet valve. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
OldBeetles Samba Member
Joined: October 10, 2024 Posts: 65 Location: Northeast
Posted: Thu Dec 12, 2024 1:08 pm Post subject: Re: 34-pic3 carb popping |
| Can you make a video showing what it's doing? |
Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 160 Location: North Alabama
Posted: Thu Dec 12, 2024 4:36 pm Post subject: Re: 34-pic3 carb popping |
| Popping = mixture too lean. |
Posted: Fri Dec 13, 2024 11:28 am Post subject: Re: 34-pic3 carb popping |
You guys are great thanks for all the tips number one. I waited till this morning when the valves were completely cold, the right side was pretty good except two were slightly tight, the driver side number three I readjusted but the other one one, the push rods had come off. You guys are so on so I reinstalled it readjusted everything check the points last night I rebuilt the carburetor cleaned everything out turn the key and the sucker fired up. Smooth is Silk sounds phenomenal. I’m a happy man, I’ve been waiting for this moment dreaming about it while doing chemo. Thank you guys and don’t forget to get your colonoscopy because it really matters. Thank you, Scott. _________________ Peace! |
Posted: Fri Dec 13, 2024 11:44 am Post subject: Re: 34-pic3 carb popping |
Glad to hear you got it running well!
This just illustrates how robust these ACVW engines are. You thought it was running badly when in fact it was running on only 3-cyls!  _________________ AshMan40
Posted: Fri Dec 13, 2024 12:56 pm Post subject: Re: 34-pic3 carb popping |
Exactly!! _________________ Peace! |
Posted: Fri Dec 13, 2024 4:21 pm Post subject: Re: 34-pic3 carb popping |
| …and prayers for you, from me, for a successful treatment and a long and fulfilling life. |
