Thing Coil Bracket Size?
sportin-wood
sportin-wood is offline
PostPosted: Sat Dec 21, 2024 2:00 pm    Post subject: Thing Coil Bracket Size? Reply with quote
So my newly acquired '73 Thing coil bracket was made from some kind of water heater straps...and I although I realize people make make parts out of things they have lying around their shop, I'm not a fan.
So I purchased a used coil bracket from one of the Classifieds on here, thinking all coils have the same diameter....WRONG! The one I got is too small. Did I get a 6V coil bracket? The newly acquired bracket has a ID of just over 2", and the coil I have requires just over 2 1/4". I looked into removing the tension screw to open up the bracket, but then I couldn't get the holes in the fan shroud to line up. What kind of specific bracket should I be looking for?
Dave
1966 Bug project
1973 Thing project
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 21, 2024 2:08 pm    Post subject: Re: Thing Coil Bracket Size? Reply with quote
Yes, you have an older bracket.
You want this one.
https://www.thesamba.com/vw/classifieds/detail.php?id=2708298
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sportin-wood
PostPosted: Sat Dec 21, 2024 2:16 pm    Post subject: Re: Thing Coil Bracket Size? Reply with quote
Excellent - Thanks Glenn!
Dave
1966 Bug project
1973 Thing project
Semper_Dad
Semper_Dad is offline
PostPosted: Sun Dec 22, 2024 11:38 am    Post subject: Re: Thing Coil Bracket Size? Reply with quote
For what its worth, I have one in the classifieds
https://www.thesamba.com/vw/classifieds/detail.php?id=2567290
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
consvws Premium Member
consvws is offline
PostPosted: Sun Dec 22, 2024 1:41 pm    Post subject: Re: Thing Coil Bracket Size? Reply with quote
he needs the larger sized bracket for the larger diameter coil. Those aftermarket ones wont work. The larger diameter coils came in 6v & 12v, so its not a matter of being early or late really.
I have a couple of the larger type, but they seem alot less common than the other smaller size clamps.
sportin-wood
PostPosted: Sun Dec 22, 2024 4:33 pm    Post subject: Re: Thing Coil Bracket Size? Reply with quote
Thanks Semper_Dad. I just purchased the bracket Glenn referred me to. If that one doesn't work/fit, I'll hit you up. I may have just started a coil bracket collection!
Dave
1966 Bug project
1973 Thing project
Semper_Dad
PostPosted: Mon Dec 23, 2024 8:09 am    Post subject: Re: Thing Coil Bracket Size? Reply with quote
FTR, the coil bracket was the original one that came with my car (AM Engine). My replacement Bosch Blue Coil came with its own bracket.
sportin-wood
PostPosted: Mon Dec 23, 2024 6:02 pm    Post subject: Re: Thing Coil Bracket Size? Reply with quote
And speaking of......The Bosch Blue Coils seem to be very expensive, but I saw this online. Seems a lot cheaper than most I've seen over $100. Your thoughts?
https://www.jittruckparts.com/Bosch-Ignition-Coil-...O-EALw_wcB
Dave
1966 Bug project
1973 Thing project
