Clutch arm travel
Brandoncox1961
Brandoncox1961 is offline
PostPosted: Thu Feb 20, 2025 11:36 am    Post subject: Clutch arm travel Reply with quote
Does anyone know how far the clutch arm on the transmission should travel when you push the clutch pedal all the way down? My bug won't go into gear when the engine is running. I replaced the clutch cable and adjusted it. Still doing the same thing. I found someone online that said it should go 3/4" to 1"?? Brand new clutch, pressure plate and flywheel last year. I didn't replace the gland nut/pilot bearing. Maybe that's bad? It grinds when I try to put it in gear.Let me know if you have any idea.
Thanks
1963 bug
1967 or 68 Benco pro street transmission
Root_Werks
Root_Werks is offline
PostPosted: Thu Feb 20, 2025 12:48 pm    Post subject: Re: Clutch arm travel Reply with quote
3/4-1" sounds about right.
If you pilot bearing is toast, could be grabbing the shaft and spinning it?
How does the pedal feel? Do you have a little "free play" before there's pressure? There should be about 1/2" before you feel pressure on the pedal. Should be resistant, then get easier once past the folcrum or tipping point (whatever they call it).
No need to run the engine.
Stick in gear, push in clutch with right foot, use left foot to see if you can roll the Bug around.
When I set my timing, why do I flush, then take a pee?
Root_Werks
PostPosted: Thu Feb 20, 2025 12:52 pm    Post subject: Re: Clutch arm travel Reply with quote
Actually a decent video:
https://www.youtube.com/watch?v=U5jyFTHo0DM
Brandoncox1961
PostPosted: Thu Feb 20, 2025 1:19 pm    Post subject: Re: Clutch arm travel Reply with quote
Yep, I have the freeplay adjusted like that. I will try the pushing the car thing when I get home. I will let you know.
Thanks
Cusser
Cusser is offline
PostPosted: Thu Feb 20, 2025 1:48 pm    Post subject: Re: Clutch arm travel Reply with quote
1. Did it shift fine after the new clutch, pressure plate and flywheel and this just started happening?
2. Does the pressure plate have a center ring? Is yours 180mm or 200mm clutch assembly?
Brandoncox1961
PostPosted: Thu Feb 20, 2025 6:54 pm    Post subject: Re: Clutch arm travel Reply with quote
#1 yes everything has been working great for the last year since I installed all the new stuff.
#2 I guess I will let you know tomorrow after I pull the engine out. I don't remember.
I was just trying to see if someone knew how far the clutch rod should move when you pushed the clutch all the way down.
jbbugs
jbbugs is offline
PostPosted: Tue Feb 25, 2025 5:17 am    Post subject: Re: Clutch arm travel Reply with quote
You might have broken welds on your clutch cable tube Inside the tunnel.
Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket!
