Rear bench seat broken, need help
Bikechunks
Bikechunks is offline
PostPosted: Sat Apr 05, 2025 1:21 pm    Post subject: Rear bench seat broken, need help Reply with quote
My rear bench seat butt portion is broken. The metal piece cracked so now I’m afraid to have people riding in the back. Would you suggest welding it or finding a new seat portion?
Red Ryder
Red Ryder is offline
PostPosted: Sat Apr 05, 2025 3:24 pm    Post subject: Re: Rear bench seat broken, need help Reply with quote
A photo would help here.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Bikechunks
PostPosted: Wed Apr 09, 2025 11:04 am    Post subject: Re: Rear bench seat broken, need help Reply with quote
Sodo
Sodo is offline
PostPosted: Wed Apr 09, 2025 11:06 am    Post subject: Re: Rear bench seat broken, need help Reply with quote
appears feasible to weld that "on-car".
(after gas-can moved).
Send me a PM if interested. I'm in south Seattle.
....KTMs, GasGas, SPOT mtb
SCM
SCM is offline
PostPosted: Wed Apr 09, 2025 4:57 pm    Post subject: Re: Rear bench seat broken, need help Reply with quote
I wonder if you could bend the flat peice (going side to side in the van) back into alignment with a hammer etc then install some sort of reinforcement like a metal bar and some nuts/bolts? Then figure out some other fix for the tubular part? There's gotta be a ton of possible fixes but welding would probably be the best.
I gotta ask - How'd that happen?
My wife bought a 92 Geo Tracker off of a high schooler and the driver's seat reclines to be fully flat but is all out of whack and twisted as if a heavy unequal weight was applied to it in unusual ways. My wife and I employ "smooth techniques" when using the back seat of our van as to avoid these issues. Laughing
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Bikechunks
PostPosted: Sun Apr 13, 2025 12:07 pm    Post subject: Re: Rear bench seat broken, need help Reply with quote
Let’s just say your boy’s got some massive game… just kidding I have some fat friends that sat on that side every time. Anyways thank you for that I’m thinking about throwing a support through the channel and welding the tube back together.
syncrodoka
syncrodoka is offline
PostPosted: Sun Apr 13, 2025 12:37 pm    Post subject: Re: Rear bench seat broken, need help Reply with quote
The base unbolts from the metal z-bed frame and can easily be swapped if you find another one, replacing the entire seat is much more work. You could disassemble and reweld yours if you have the tools.
Looking at the rust and how much shiny metal(not much) is at the break point this has been broken for a long time.
