6v Gearbox, 12v flywheel engine
Boroboy63
Boroboy63 is offline
PostPosted: Sat May 03, 2025 3:48 am    Post subject: 6v Gearbox, 12v flywheel engine Reply with quote
I have fitted a 1600 twin port to my 62 notch, which still has a 6v transaxle.
I clearanced the gearbox before I fitted the engine to make way for the larger flywheel, but I did not take enough material off. So as I fitted the engine, I could not get it in altogether, so I turned the engine over, until I could get the engine in a bit further, and then repeated this until I got the engine fitted.
Running the engine, there is no noise, but, driving it it is very noisy, I initially thought the diff was defective, noisy all the time, but especially on overrun.
I got the car registered here in Australia, and have driven it about 30 kms, without any change in the noise level!
I have removed the engine, to get the transaxle rebuilt, I am just thinking is there any possibility that the flywheel is still catching on the g/box? I repeat, it is completely noise free when the engine is running with the car stationary.
I have taken the engine and box out, in order to get the gearbox rebuilt, as I dont want to waste time putting the engine back in, and ending up back at the start!
Surely it would make a noise on tickover if the flywheel was catching?
If it only caught when I was driving surely I have done enough kms for it to have removed any material it was fouling on?
Thoughts would be appreciated, thanks in anticipation.
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sat May 03, 2025 11:12 am    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
If the flywheel was still catching the transmission housing, there would be further tell-tale metal dust in that area. Runout on the flywheel should be very small, so once there is enough clearance, it should be fine. Keep in mind that the mainshaft (and pinion shaft gears) are also spinning when idling while stationary. As a result, isn't the noise more likely a pinion shaft bearing or a differential problem? BTW, if you are still 6V, there exists a '66 flywheel, 109 teeth, that mates 6V starter transmissions to later style 12V O-ring cranks, 200mm clutch, not requiring any grinding.
- Zeuxius, 400 BC
Bobnotch
Bobnotch is offline
PostPosted: Sat May 03, 2025 12:15 pm    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
Yeah but, all type 3s came with a 200mm clutch, even the 6 volt cars.
I've ground out a couple of 6 volt trans axles, to fit a 12 volt engine in, so you need to make sure the flywheel clears those 4 spots for sure. Your noise could be a clutch unit, or something internal to the trans.
Was the trans shifting smoothly and or making noise before? Just asking.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Boroboy63
PostPosted: Sat May 03, 2025 8:21 pm    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
Thanks Guys
I originally thought it was the diff, I had actually forgot that it was a six volt trans, and that I had clearanced the gearbox doh!
Trouble is now that I have taken it out, I dont want to put it back, until I know that its not the trans, so I am going to have to have it rebuilt.
I know an option is to fit a 6v flywheel, wasp do a starter that suits that application, so that could be an option.
I will fit a new clutch as a matter of course.
Turning the half shafts with the transmission out, it feels smooth and in order, whilst it was fitted with the engine in, you could hear it rumbling just pushing it on the drive. (With the gearbox in neutral).
The box shifts really nice, doesn't jump out or anything like that.
The joys of restorations!
Zwitterkafer
PostPosted: Sun May 04, 2025 10:50 am    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
No, not all Typ3 came with a 200mm clutch. Up until engine number 65745 a 180mm clutch was used with flywheel 113 105 271B. In any case, now that the assemblies are removed from the car, accurate diagnosis of the noise may be next to impossible. (Barring new scrape marks present in the trans bellhousing.)
- Zeuxius, 400 BC
Boroboy63
PostPosted: Wed May 07, 2025 6:37 pm    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
just an update, apparently the pinion bearing is absolutely stuffed. From my point of view, I'm glad they have found something.
Zwitterkafer
PostPosted: Thu May 08, 2025 8:27 am    Post subject: Re: 6v Gearbox, 12v flywheel engine Reply with quote
That makes total sense, given the symptoms. Unfortunate, but it will be so much nicer once repaired! Best of luck!
- Zeuxius, 400 BC
