Wisdumb Samba Member
Posted: Wed May 21, 2025 12:56 pm Post subject: VW Sand Rail noises... any ideas? |
Hello everyone!
I've been working on restoring a sand rail after it was in a fire and I've run into an issue that I can't diagnose. Lots of noises coming from behind me when driving.
I've done a lot of work to this rail recently, but it wasn't drivable before the work so I don't have a reference point to know if any of the new parts are causing the issue. I've replaced all of the engine tins, fan/shroud/hardware, CVs, rotors/calipers, shocks, ball joints, distributor, plugs, wires, carbs, and probably some things I can't remember at the moment.
I recorded the sounds and made a video with subtitles at this link:
https://www.youtube.com/watch?v=hpE4KGiI14w
If anyone has any insights, I am all ears.
Thanks in advance to anyone that spends any amount of time looking at this post. I appreciate all of your knowledge and experience. |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1046 Location: half a bubble from plumb
Posted: Wed May 21, 2025 3:13 pm Post subject: Re: VW Sand Rail noises... any ideas? |
Howdy ... & welcome
Maybe CV joints.
Overdue for valve adjustment also.
Possible exhaust leak as well.
Welcome to the madness ... stay safe
jinx
PS :
Cool forum handle, made me chuckle ! _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1056 Location: South Florida
Posted: Thu May 22, 2025 8:27 am Post subject: Re: VW Sand Rail noises... any ideas? |
Hard to say with so many various sounds, but I am hearing what might be the cooling fan scraping inside fanshroud?
While at idle (with parking brake set) grab hold of fanshroud top, then push & pull, to see if any change in sound. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3642 Location: West Coast (Michigan's)
Posted: Thu May 22, 2025 11:42 am Post subject: Re: VW Sand Rail noises... any ideas? |
It seems like you have something creating a harmonic whether that be a CV or bearing that needs attention and it's making everything shake and rattle. The lower frequency rattle sounds like the culprit and I would start by checking the cvs. Make sure ther are clocked correctly and all the cv parts are fitting together right. Google a video on how to do this if you need to. _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Posted: Thu May 22, 2025 11:43 am Post subject: Re: VW Sand Rail noises... any ideas? |
I don't think it's the engine. Can't be sure but that's not screaming out at me for some reason. _________________ Brian H.
Posted: Thu May 22, 2025 11:45 am Post subject: Re: VW Sand Rail noises... any ideas? |
I've also heard something similar when there was a tire issue. _________________ Brian H.
BFB Samba Member
Posted: Thu May 22, 2025 6:36 pm Post subject: Re: VW Sand Rail noises... any ideas? |
If it burnt if a fire then its probably ghosts _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Wulfthang Samba Member
Posted: Thu May 22, 2025 7:50 pm Post subject: Re: VW Sand Rail noises... any ideas? |
| BFB wrote: |
| If it burnt if a fire then its probably ghosts |
That's just cruel, man! Ghosts. Sheeiit. Obviously, It's not ghosts. Something came back with it from The Other Side. (Insert twilight Zone music here) Some Thing. |
BFB Samba Member
Posted: Sat May 24, 2025 4:46 pm Post subject: Re: VW Sand Rail noises... any ideas? |
| Wulfthang wrote: |
| BFB wrote: |
Oh shit thats even better!
Maybe it’ll turn out to be like “Christine” _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Posted: Sat May 24, 2025 7:44 pm Post subject: Re: VW Sand Rail noises... any ideas? |
| Yeah, I've sometimes wondered if my car was a type of Christine, with as much of my blood as she's bled me for. |
Posted: Sat May 24, 2025 7:48 pm Post subject: Re: VW Sand Rail noises... any ideas? |
| Yes, I am hearing some kind of drive train noise. That clicking on start up might be a bad wheel bearing or a CV joint. Later on, it sounds like the fan is dragging on the housing. |
WaterBuggy_24 Samba Member
Posted: Sun May 25, 2025 12:12 pm Post subject: Re: VW Sand Rail noises... any ideas? |
| Wisdumb wrote: |
Hello everyone!
The loudest sound of the "clicking/clacking", in my opinion is definitely part of the drive train after the engine. Say like differential or cv joints.
If you let the transaxle slow the vehicle instead of the brakes, how does it change the tone of the sound. Does it quiet or get louder? _________________ One day, I may learn.
Probably not today though. |
