valve clearance
lboos
lboos is offline
PostPosted: Fri May 23, 2025 8:40 am    Post subject: valve clearance Reply with quote
Between valve adjustments, does the valve clearance increase or decrease do to normal wear ? Thanks
bsairhead
bsairhead is offline
PostPosted: Fri May 23, 2025 8:46 am    Post subject: Re: valve clearance Reply with quote
lboos wrote:
Between valve adjustments, does the valve clearance increase or decrease. Thanks
If parts wear evenly, neither.
BMFBMF
BMFBMF is offline
PostPosted: Fri May 23, 2025 1:36 pm    Post subject: Re: valve clearance Reply with quote
Generally valve seats wear and the gap closes up.
-----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day.
bsairhead
PostPosted: Fri May 23, 2025 1:49 pm    Post subject: Re: valve clearance Reply with quote
Or the adjusters wear more and it opens.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri May 23, 2025 1:56 pm    Post subject: Re: valve clearance Reply with quote
Or the valve stem stretches and the gap closes up.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
PostPosted: Fri May 23, 2025 2:35 pm    Post subject: Re: valve clearance Reply with quote
I would find it hard to believe that the stem would stretch more than the adjuster would wear.
lboos
lboos is offline
PostPosted: Fri May 23, 2025 4:41 pm    Post subject: Re: valve clearance Reply with quote
I was just thinking, today I adjusted the valves on my 1972, I never noticed it before but on two of the cly's two of the valves were so tight I could not get .006 blade in, so I guess that means the valve clearance decrease's with normal wear. Thanks anyway Confused .
bsairhead
PostPosted: Fri May 23, 2025 5:50 pm    Post subject: Re: valve clearance Reply with quote
lboos wrote:
I was just thinking, today I adjusted the valves on my 1972, I never noticed it be for but on two of the cly's two of the valves were so tight I could not get .006 blade in, so I guess that means the valve clearance decrease's with normal wear. Thanks anyway Confused .
That would only be logical if they all did. So the other 2 cylinders all was normal? And was it just exhaust or intake or one of each? And were the 2 cylinders on the same bank?
lboos
lboos is offline
PostPosted: Sat May 24, 2025 5:31 am    Post subject: Re: valve clearance Reply with quote
bsairhead wrote:
[quote="That would only be logical if they all did. So the other 2 cylinders all was normal? And was it just exhaust or intake or one of each? And were the 2 cylinders on the same bank?
Your prob. right, The tight valves were on #2 and #4 cly don't remember which valve, the other valves were slightly loose.
The reason I adjusted the valves was when I was going up a hill I noticed a valve rattle when under a load, after the valve adjustment no more valve rattle.
Thanks for all the advice, I've been around VW bugs since the 60's, love to drive them, but still don't know a whole lot about them mech Smile .
baldessariclan
baldessariclan is offline
PostPosted: Sat May 24, 2025 6:11 am    Post subject: Re: valve clearance Reply with quote
Yeah, you want to keep an eye on any valves that require significant readjustment over short intervals, especially exhaust valves. If one or more of them is consistently tight every time you check & readjust, can sometimes be a sign that the stem is stretching, and may be getting ready to break - !!
