Snoopy1971 Samba Member
Joined: May 15, 2020 Posts: 329 Location: Parkville, Maryland
Posted: Fri May 30, 2025 3:49 pm Post subject: Piston/Cylinder & Heads Opinions |
I have a ’68 Beetle with an H case that started life as a 1500. Somewhere along the lines, somebody made it into a DP 1600.
So I had a recent oil leak, that I posted about 2 months ago, that I figured was the oil cooler or oil cooler seals. I replaced the cooler and seals and did some other cosmetic things while the engine was out.
I got the engine all back together and wanted to run it outside of the car before I put it back in the car so I could check the oil leak. So I borrowed a friend’s remote start setup and got it running as seen here:
https://youtube.com/shorts/eC8Vz9KuUnE?si=PDre2LLQjB6lSjvG
Let it idle for like 20 mins and confirmed that there was no leak. Before I put it back in the car, I decided to do a compression test. That didn’t turn out so well:
#1 – 97
#2 – 124
#3 – 0
#4 – 90
Great, no compression in #3. Did a leak down test and confirmed it was leaking back through the case. So took it all back apart and removed the head to find a nice little ole chunk gone from #3 piston:
Alrighty then, it’s time to get new pistons & cylinders. My heads are old and crusty looking and the valves are crappy looking, so I plan on just replacing the heads too. So I have some questions to the knowledgeable folks around these parts.
This is just a stock engine, nothing special about it ... There are so many options out there for pistons/cylinders and heads, it's a little overwhelming. On some vendor websites, it is also hard to tell which items they make and which ones are somebody else's (for example CB Performance, I believe they make some of their own stuff).
What are some good brands of pistons/cylinders and heads? I buy from CIP1 a lot, but it seems for heads, the only brand they have is Empi. I'm hoping to stay away from their Chinesium stuff. Several friends have used AA and all told me they have all had great experiences with them ... But I know that's made in China as well ... are they "better" Chinese parts?
What about Mahle and Moresa for pistons?
What about Autolinea heads? I saw them on AA's website being made in Brazil, but then on another vendor's site, it says they are made by Empi ... so confusing.
I don't really want to split my case, so I am debating between just doing a stock replacement to keep my engine at 1585 (85.5mm pistons) or bumping it up a little to 1679 (88mm pistons). I know that AA makes a 88mm drop in kit to reuse the same heads, but then that means the cylinder walls will be thinner. I was thinking of getting the AA 88mm thick-walled P&C kit, and it says the wall thickness is 4.9mm, so need heads bored out for 92mm.
Was thinking about this top end kit to bump it to 1679 (for some reason, the AA site says its 1688):
https://aapistons.com/collections/top-end-rebuild-...-1641-1688
or maybe buy piecemeal with Autolinea brazillian heads:
https://aapistons.com/collections/vw-piston-liner-...-90-5-head
https://aapistons.com/collections/cylinder-heads-c...e-high-rev
So whats everyone's experience with the various manufacturers of stock heads and P&Cs? _________________ 1968 Bug |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33149 Location: Hot Arizona
Posted: Fri May 30, 2025 4:36 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
Snoopy1971 wrote: |
So whats everyone's experience with the various manufacturers of stock heads and P&Cs? |
Way back in 1976, I built a 1600cc SP up to a 1835cc DP, got most of my parts from CB Performance.
When I resurrected my 1970 sedan in 2016-2017, I was rebuilding a 1600cc DP engine from my 1971 Convertible, and I used Moresa pistons and cylinders from CB as well, manufactured by the OEM supplier to VW of Mexico. https://www.cbperformance.com/product-p/1000.htm
I was happy with those, still doing fine, and the pistons were super-close in weight. I believe this kit came with made in USA piston rings too; one would need to check somewhere in my resurrection thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=664950&highlight=resurrection+1970
I had my cylinder heads re-done at local machine shop. I've heard that MoFoCo cylinder heads are made in USA, check that.
I still run 1835cc DP in my 1971 Convertible. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1122 Location: San Francisco, CA
Posted: Fri May 30, 2025 5:01 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
I am running 1641 AA P&Cs. I dont have a ton of miles on them, but no issues so far.
The engine sat for a decade shortly after the rebuild too, and it still fired right up no issue. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
dopeboat Samba Member
Posted: Fri May 30, 2025 7:25 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
The autolinea heads are poop. I had them on my beetle (Autolinea GO1s) and they are brutally bad as far as casting flash and blocked cooling passages go. There are other issues as well but I can’t remember them off the top of my head. I think having to do with valve seats.
Otherwise my only experience is with stock heads. Just would advise not to spend money on the Autolinea heads. _________________ '77 FI Bahama Blue Type 1 |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4940 Location: Stuck in Ohio
Posted: Sat May 31, 2025 8:29 am Post subject: Re: Piston/Cylinder & Heads Opinions |
Cusser wrote: |
When I resurrected my 1970 sedan in 2016-2017, I was rebuilding a 1600cc DP engine from my 1971 Convertible, and I used Moresa pistons and cylinders from CB as well, manufactured by the OEM supplier to VW of Mexico. https://www.cbperformance.com/product-p/1000.htm |
Yes, I did read that about Moresa pistons, so thats why they are on my list. Great to hear that they stand the test of time!
It seems that AA are the only ones who make a thick walled 88mm piston, so I'm still leaning towards them, but I'm still keeping an open mind on all the others!
Cusser wrote: |
I had my cylinder heads re-done at local machine shop. |
I did check your resurrection thread, but only searched for where you mentioned the Moresa pistons ... Looks like a great thread to sit down and read the whole thing! When I was reading the page that mentioned the pistons, I was wondering what heads you used, but then realized you reused your OE heads ... holy cow they look pristine, they were so clean looking, I thought they were new!
Cusser wrote: |
I've heard that MoFoCo cylinder heads are made in USA, check that. |
Yes, I found somebody else mention them in another thread right afetr I posted this thread ... They look pretty good to my untrained eye ... I am seriously considering these. And they carry the AA 88mm thick walled pistons too!
Looks like they offer 2 diff stock heads ... one made elsewhere that MoFoCo dresses up, and one made in-house ... both same price.
https://www.mofoco.com/item/New_Type_1_Stock_Dual_Port_Cylinder_Head/4251/c152
https://www.mofoco.com/item/Mofoco_040_Dual_Port_N..._/237/c152
Thank you for your insight!! _________________ 1968 Bug |
Posted: Sat May 31, 2025 8:31 am Post subject: Re: Piston/Cylinder & Heads Opinions |
dopeboat wrote: |
Otherwise my only experience is with stock heads. Just would advise not to spend money on the Autolinea heads. |
Thanks for the tip ... yeah, it seems many of the listings on the vendor sites dont list who makes the heads they sell ... so frustrating _________________ 1968 Bug |
Posted: Sat May 31, 2025 8:44 am Post subject: Re: Piston/Cylinder & Heads Opinions |
Buggeee wrote: |
I've had great experiences with multiple sets of pistons from AA and a couple sets of heads from AA too on various builds. Everything checked out, slapped them on and worked great. Still running years later. I will do it again too. |
Yeah I have had several friends tell me they used AA pistons, not sure what heads they used.
Besides the MoFoCo heads KI mentioned above, I am considering this rebuild kit from AA ... not sure why they call it a 1688, when everyone else calls it a 1679:
https://aapistons.com/collections/engine-rebuild-k...-1641-1688
Just not sure of the quality of the heads in this kit. $780 for this kit and free shipping vs about $850 + ~$160 shipping for the items from MoFoCo _________________ 1968 Bug |
Posted: Sat May 31, 2025 9:03 am Post subject: Re: Piston/Cylinder & Heads Opinions |
I would not recommend oversized slip in pistons. Get stock.
I regret my oversized slip ins. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Sat May 31, 2025 9:23 am Post subject: Re: Piston/Cylinder & Heads Opinions |
talljordan wrote: |
I regret my oversized slip ins. |
Can you elaborate on that ... why do you not recommend it and regret it? _________________ 1968 Bug |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1030 Location: South Florida
Posted: Sat May 31, 2025 9:29 am Post subject: Re: Piston/Cylinder & Heads Opinions |
Snoopy1971 wrote: |
... What about Mahle and Moresa for pistons? |
Mahle has stay'd close to stock, Moresa is stock for Mexican bugs which apparently have a lower compression ratio probably due to the gasoline down there. I was considering Moresa for my "spare" engine, but went with AA 'cuz they match my worn-out Mahle pistons in terms of deck height, and thus, compression ratio. More info here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9552221&highlight=preping+175#9552221 |
Posted: Sat May 31, 2025 9:30 am Post subject: Re: Piston/Cylinder & Heads Opinions |
Slip in oversized means that the cylinder walls are thinner.
I have no real noticable increase in power from the extra size, so I just sacrificed long term reliability and cooling for no real benefit.
Thicker cylinders also are less likely to warp.
I haven't had any issues with mine. But I wish I had either kept it stock, or gone all the way and machined the case for larger cylinders _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Sat May 31, 2025 9:36 am Post subject: Re: Piston/Cylinder & Heads Opinions |
talljordan wrote: |
I haven't had any issues with mine. But I wish I had either kept it stock, or gone all the way and machined the case for larger cylinders |
Oh yeah yeah, I know about the cylinder walls being thinner for the 87 & 88mm slip in kits, but somewhere above I did mention that I was looking at the thick walled 88mm ones with a head machined to 92 mm piston size. _________________ 1968 Bug |
Cusser Samba Member
Posted: Sat May 31, 2025 10:32 am Post subject: Re: Piston/Cylinder & Heads Opinions |
talljordan wrote: |
I've been using thin-wall 92mm cylinders for 29 years now in the same engine, which has not been apart in all that time, no issues, Arizona.
Snoopy1971 wrote: |
When I was reading the page that mentioned the pistons, I was wondering what heads you used, but then realized you reused your OE heads ... holy cow they look pristine, they were so clean looking, I thought they were new! |
I also could not believe that the local VW machine shop could do such a great job on my cylinder heads, https://europeanautomachine.com/. Each also had two exhaust studs that were off-kilter after I drilled and re-tapped to 8mm x 1.25mm for new studs after they broke off after Mrs. Cusser backed into a parking block. So those were fixed right too.
Before machine shop, after a decade of sitting outside
After machine work
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7507 Location: Houston, Texas
Posted: Sat May 31, 2025 12:32 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
If you are sticking with stock just grab a set of the China 1600 heads and a set of stock Mahle's from Brazil. _________________ www.vwnos.com [email protected]
Posted: Sat May 31, 2025 2:04 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
Nevermind, I just decided to just fix the piston ... just needs a little JB Weld
Looks like they were a set of Mahle pistons. _________________ 1968 Bug |
heimlich wrote: |
If you are sticking with stock just grab a set of the China 1600 heads and a set of stock Mahle's from Brazil. |
Why you say that ... is the Chinese stuff good enough for stock applications? _________________ 1968 Bug |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11207 Location: Oregon
Cusser Samba Member
Posted: Sun Jun 01, 2025 12:01 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
Hmmm - I bought a rebuilt transmission from MoFoCo in 2018, installed that in my 1970 sedan, and it's been fine..... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Jun 01, 2025 12:06 pm Post subject: Re: Piston/Cylinder & Heads Opinions |
Yeah I had a few friends tell me if some horror storries they read online about Mofoco stuff so I decided to steer clear.
I ended up putting my order in online from AA for their 1688 top end rebuild kit _________________ 1968 Bug |
