Back seat woes
Alleycat1990
Alleycat1990 is offline
PostPosted: Tue Jun 10, 2025 4:56 pm    Post subject: Back seat woes Reply with quote
I put a bunch of stuff under the backseat/Bed while I was working in my Vanagon. Now I cannot for the life of me open it. I pull the lever and grab the handle and now way will it open it is like it is stuck. Anyone have any ideas?
1990 Vanagon GL purchased fall of 2024
never winter driven and well maintained
minor repairs needed example odometer
markswagen
markswagen is offline
PostPosted: Tue Jun 10, 2025 5:59 pm    Post subject: Re: Back seat woes Reply with quote
push down as you pull on the lever.
failing that.
619 201 0310
Alleycat1990
PostPosted: Tue Jun 10, 2025 6:04 pm    Post subject: Re: Back seat woes Reply with quote
I have tried everything short of an exorcism. No cigar. Tomorrow morning I will try unscrewing the front panel. Or a stick of dynamite. Thanks.
markswagen
PostPosted: Tue Jun 10, 2025 7:19 pm    Post subject: Re: Back seat woes Reply with quote
westfalia
tin top
1990 ?
tin top, the seat base just pulls up.
westy, early the button left to release the clip.
late pull it directly out for the same result.
push down on the seat base, as you do either.
619 201 0310
dhaavers
dhaavers is offline
PostPosted: Tue Jun 10, 2025 7:38 pm    Post subject: Re: Back seat woes Reply with quote
Sit hard & heavy on the seat, pull the pin, lift the seat.
…and may God be with you. <sign of the cross>
- Dave
"The WonderVan"
Alleycat1990
PostPosted: Wed Jun 11, 2025 3:34 am    Post subject: Re: Back seat woes Reply with quote
I tried all 180 pounds of me pushing on the back kneeling on it.I put my arm through the little hole. Looked it up in Bentley so I could see what the mechanism looks like . It might as well be a kids drawing.
Not a tin top.
dobryan Premium Member
dobryan is offline
PostPosted: Wed Jun 11, 2025 5:09 am    Post subject: Re: Back seat woes Reply with quote
Not a tin top.
It likely has something under the seat that has shifted and is blocking the release lever. You may need to get creative to find a way to move anything that is near the latch mechanism.
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
Alleycat1990
PostPosted: Wed Jun 11, 2025 5:19 am    Post subject: Re: Back seat woes Reply with quote
Thanks for the suggestions much appreciated. I tried that last night I am going to try again this morning with a fresh brain and a large Expresso or a bigger hammer N. Cool
vanis13
vanis13 is offline
PostPosted: Wed Jun 11, 2025 5:24 am    Post subject: Re: Back seat woes Reply with quote
Grind off the heads on the carriage bolts (near delete in this picture), push the bolt shanks back and the mechanism (hopefully) pulls up.
.... And then delete this latch as in this post (second page does an alternate way to prevent locking without deleting latch)
https://www.thesamba.com/vw/forum/viewtopic.php?t=721523
Alternately, you may be able to reach in from behind the seat, from the engine lid side, to dislodge the offending item.... You may also be able to get to the screws on the hinges that hold the seat to remove them to show even more room from the back.
Alleycat1990
PostPosted: Wed Jun 11, 2025 5:28 am    Post subject: Re: Back seat woes Reply with quote
Now that is the picture and instructions needed! Mega thanks
Alleycat1990
PostPosted: Wed Jun 11, 2025 10:11 am    Post subject: Re: Back seat woes Reply with quote
I tried everything still could not get it open . I took my sawmill and cut the u bracket. Now I need to find one.
vanis13
vanis13 is offline
PostPosted: Wed Jun 11, 2025 10:13 am    Post subject: Re: Back seat woes Reply with quote
how did you get to it?
Alleycat1990
PostPosted: Wed Jun 11, 2025 10:17 am    Post subject: Re: Back seat woes Reply with quote
2 pieces of hardwood with a 4 foot crowbar.
dobryan is offline
PostPosted: Wed Jun 11, 2025 10:32 am    Post subject: Re: Back seat woes Reply with quote
What was preventing it from unlatching?
Dave O
vanis13
vanis13 is offline
PostPosted: Wed Jun 11, 2025 10:37 am    Post subject: Re: Back seat woes Reply with quote
by lifting up the back / from the engine side or something else?
I can tell its frustrating for you and clarity will help the next person afflicted with this. You are not the first.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jun 11, 2025 11:15 am    Post subject: Re: Back seat woes Reply with quote
Too late now, but when that happens, yank on the back rest while somebody pulls the latch. Might need some weight on the seat too, so the person pulling on the back can put one knee down.
