What jack to carry for changing a flat tire?
MimosaSix
MimosaSix is offline
PostPosted: Thu Jun 19, 2025 1:05 pm    Post subject: What jack to carry for changing a flat tire? Reply with quote
I have a 72 Super and it did not come with any type of jack for changing a flat. I was wondering what type of scissor or Bilstein jack do you carry for changing a flat while out on the road? Also is there a good spot on the car for even using a scissor jack without lifting the entire side? I need to get a jack just in case. I searched the forum and didn't find a great answer. Thanks!
bsairhead
bsairhead is offline
PostPosted: Thu Jun 19, 2025 1:24 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
A small trolley jack that fits under the hood. Or the back seat.
my3bugs
my3bugs is offline
PostPosted: Thu Jun 19, 2025 1:30 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
ya its like a mini floor jack , got mine at harbor freight for under 40 dollars . much more versatile . but i also have the original jack in the bug Smile
i keep a short piece of 2 by 4 to set between the jack and car so it doesnt leave any marks .
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Jun 19, 2025 2:11 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I carry a small scissor jack which came on older Toyotas. On the front I jack on one of the end frames of the front suspension beam. For the rear I jack on the bottom of the shock housing. I also carry several short 2x4 blocks, a small square of plywood to go under the jack if on dirt. Has worked for me for over 55 years. Good luck
NJ John
NJ John is offline
PostPosted: Thu Jun 19, 2025 2:53 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
When are they going to make a trolly jack in aluminum!
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Thu Jun 19, 2025 2:59 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
https://www.amazon.com/Profile-Professional-Trolle...NX6L5?th=1
But it'll cost you twice as much.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
NJ John
NJ John is offline
PostPosted: Thu Jun 19, 2025 3:30 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I actually have that jack. I’m referring to the stubby ones. Sometimes their in a plastic case, but still weigh a bunch.
jeffrey8164
jeffrey8164 is offline
PostPosted: Thu Jun 19, 2025 3:34 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I used to use a small scissor jack but eventually sought and bought an original Bilstein. I like it a lot better than the scissor and there’s actually a spot for it. Sure, it lifts one whole side of the car but, so what.
I haven’t had a chance to change a flat yet, but I have practiced putting the car up and down with it.
My biggest problem is putting the flat somewhere as my wheels are too wide to fit in the spare well.
Volkswagen!
(Compression 8.7:1)
MimosaSix
PostPosted: Thu Jun 19, 2025 5:48 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
Where are using as a jacking point? Say if you need to change a front flat.
vamram Premium Member
vamram is offline
PostPosted: Thu Jun 19, 2025 7:24 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I carry the original but am also on the lookout for a better option. A guy in my neighborhood has a '73 Super that his father bought new. He damaged it last year when the body metal buckled above the jack slot while doing some work on the car.. Real downer. I've had to use it on 3 occasions without problems, but definitely want an alternative. The aluminum one looks good, even if pricey.
Click to view image
Save the Supers!!
meranda
meranda is offline
PostPosted: Fri Jun 20, 2025 3:47 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
The answer is NEVER have a flat tyre!!!
Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan
Multi69s
Multi69s is offline
PostPosted: Fri Jun 20, 2025 9:17 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
Can we say Slime - your tire man will love you for it. Twisted Evil
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
bugger-off
bugger-off is offline
PostPosted: Fri Jun 20, 2025 9:25 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
A bottle jack?
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Jun 20, 2025 10:20 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I just used a Honda scissors jack. Put the head directly under the original jacking point and jacked it up. The scissors jack is lightweight, compared to a floor jack, and it's not rolling around and banging into your trunk lid. I also use a short 2x4 to place on the ground before placing the jack on it.
Tim
Let's do the Time Warp again!
Richard O'Brien
johnnyvw164
johnnyvw164 is offline
PostPosted: Fri Jun 20, 2025 10:53 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I wonder how this one actually works?
https://www.amazon.com/dp/B07W5L3L8B/ref=sspa_dk_d...M&th=1
bugger-off
PostPosted: Fri Jun 20, 2025 11:04 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
It probably doesn't. Buyer beware.
NJ John
NJ John is offline
PostPosted: Fri Jun 20, 2025 11:17 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
bugger-off wrote:
A bottle jack?
No, just a small floor jack in a case.
Bobs67vwagen
PostPosted: Fri Jun 20, 2025 11:32 am    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
Mimosa6 if the flat is in the front I jack under the end portion on the front suspension beam that is down lower than the bottom tube. In the back I jack under the shock housing. I started doing this many years ago in the northeast( long Island) , because many of the bugs I had back then had rusted around the jacking points which would sometimes cave in when you tried to use them.Bob
scottyrocks
scottyrocks is offline
PostPosted: Fri Jun 20, 2025 5:38 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
That's exactly what I have in my Beetle and Civic, wood and all, except I use pieces of 2x6.
– D. Tartt, 'The Goldfinch'
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jun 20, 2025 5:43 pm    Post subject: Re: What jack to carry for changing a flat tire? Reply with quote
I carry a can of Fix-A-Flat.
I have different size tires front and read (195/55-15 and 205/60-15) so neither will fit in the spare tire well.
My car is lowered so a stock 165-15 will hit the fender. The transaxle has a ZF-LSD so running different size tires left/right can damage the friction clutches.
I do carry a Porsche 928 scissor jack. It will fit under the lowered front, folds very small and is made of aluminum so it's very light.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
