Derickpete Samba Member
Joined: October 01, 2013 Posts: 22 Location: Gardnerville Nv
Posted: Wed Jul 02, 2025 7:29 pm Post subject: Headlamp rocker switch |
I am installing a on-off-on rocker switch for my headlamps. I’m connecting the running lights to work on both sides of the switch. They are all leds. What diodes do I need to keep the current from bleeding back between the high/ low beams. |
indianpeaksjoe Samba Member
Posted: Thu Jul 03, 2025 8:53 am Post subject: Re: Headlamp rocker switch |
So the high beams and low beams go into the diode and the running lights are on the out of the diode. correct? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20807 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jul 03, 2025 11:06 am Post subject: Re: Headlamp rocker switch |
Derickpete wrote: |
Bingo.... _________________ “Fear The Government That Wants To Take Your Guns"
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3490 Location: West Coast (Michigan's)
Posted: Tue Jul 08, 2025 8:40 am Post subject: Re: Headlamp rocker switch |
I always run relays and then diodes aren't necessary. _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Wulfthang Samba Member
Posted: Tue Jul 08, 2025 7:20 pm Post subject: Re: Headlamp rocker switch |
ORANGECRUSHer wrote: |
I always run relays and then diodes aren't necessary. |
Yeah, me too plus if you're using higher power lights, the relays can handle the power with no problem. A good supplier of relays are audio supply houses. They carry waterproof heavy duty ones. |
