002/091 Bell Housing Starter???
Dan_Lockwood
Dan_Lockwood is offline
PostPosted: Mon Jul 07, 2025 12:04 pm    Post subject: 002/091 Bell Housing Starter??? Reply with quote
Hello again,
I have a 5-rib with an 091 bell housing transaxle in my sand rail build. I have a Type 1 2276 stroker motor that will be built and used in it.
I picked up an 091 front bell housing at a swap meet this spring and it's going to be mounted onto one of my three motor stands and I hope to use it as a start up stand when the motor is completed.
On my sand rail 091 bell housing, I have the correct 091 adapter and TDI starter set up. I really don't want to pull the parts from my sand rail bell housing to the run stand every time I want to fire up a motor.
My question, what starter do I need to buy for the 091 bell housing with a Type 1 motor and 12v flywheel? Do I just purchase a '76 bus starter?
Thanks, Dan
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Jul 07, 2025 3:33 pm    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
Yes you need a starter for the 091. Starter has to throw further out, and inside bell housing is deeper.
There has been others that milled the 091bell housing at starter location to use a standard Bug starter. I think it does require some filler weld in one place.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Dan_Lockwood
PostPosted: Mon Jul 07, 2025 4:00 pm    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
Thanks, at least I know what I need to do now!
Dan
fl59bug
fl59bug is offline
PostPosted: Tue Jul 08, 2025 7:55 am    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
Here is the one I have:
https://socalautoparts.com/product/starter-bus-12-volt-hi-torque-fits-091-transmission/
Ted
jim martin
jim martin is offline
PostPosted: Tue Jul 08, 2025 8:17 am    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
^^^^^^ THIS ^^^^^^^
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
Dale M.
Dale M. is offline
PostPosted: Tue Jul 08, 2025 9:32 am    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
Think it would be cheaper all around to just find a 002 bellhousing.... I paid $10 for mine with starter.....
jsturtlebuggy
PostPosted: Tue Jul 08, 2025 2:09 pm    Post subject: Re: 002/091 Bell Housing Starter??? Reply with quote
Dale, Have you looked lately for a used 002 bell housing?
If you can find one for Cheap let Dan Know.
Have seen what the prices are now for a Bus IRS transaxle?
Joseph
Elrod Motorsports
