WTGPhoben Samba Member
Posted: Tue Jul 08, 2025 5:12 pm Post subject: Pinging Puzzle 2.3L Digifant |
I recently had an engine built (2.3L High Compression pistons , oil squirters, mansi ratio rockers, mansi injectors, mansi oil pump) along with a Digifant EFI (from the wiring colors, the harness appears to be from an 89). EFI was a takeoff and was assumed working, but wasn't specifically tested in any way. I have a few thousand miles on the new engine build, and overall it runs fine and passes CA smog with plenty of margin, but under certain conditions, it seems like I believe I'm getting some really bad spark knock:
- Warm Engine (180-200F oil), High load, near full-throttle 3200RPM: Sounds like light pinging 1-2 pings every second on an uneven cadence)
- Hot engine (215F oil), Moderate-load, near full-throttle 4200+ RPM: Ping on every cylinder fire.
In both cases, backing off the throttle will make it go away and pushing it again will make it come back. I run 91 octane fuel. Timing is set to the standard 35deg at 3000 RPM (AFAIK - will double check this obviously).
The above symptoms occur at sea level in warm weather. Old gas (which loses octane over time) seems to make the situation easier to trigger.. Higher altitude makes it harder (above 3000ft, I have not ever noticed it), presumably because the thinner air changes the conditions that are causing it.
Does anyone have theories on what could be happening here? I'd love to have some ideas before I just start changing stuff willy nilly or doing a full diagnostic of everything (which I don't have time for and would rather not pay for someone else to do at market rate if I can avoid it).
I will report back on any suggestions I end up trying. _________________ '85 Full Camper #westyjanefonda |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10002 Location: Where?
Posted: Tue Jul 08, 2025 5:30 pm Post subject: Re: Pinging Puzzle 2.3L Digifant |
Larger displacement is generally associated with increased pinging/knocking. Higher compression is also associated with increased pinging/knocking. Considering you have both higher compression and larger displacement while using the same timing spec and FI as the 2.1 which does not have a knock sensor, that combination seems to explain it. Not really a puzzle, considering those factors I would be kinda surprised if it didn't ping without an adjustment to the timing. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18748 Location: Retired South Florida
Posted: Tue Jul 08, 2025 6:04 pm Post subject: Re: Pinging Puzzle 2.3L Digifant |
I agree with Waldo. What was the calculated compression ratio? I’d try backing off the timing 2 degrees at a time. Do that till the knocking is not present. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3404 Location: Vancouver, B.C.
Posted: Tue Jul 08, 2025 6:45 pm Post subject: Re: Pinging Puzzle 2.3L Digifant |
You can protect that high-compression engine with the model 1004-Uni.V3 knock control system from J&S Safegaurd. Many owners of older EFI and carbureted vehicles have succefully installed that system to control knock. At only $695.00, the cost of saving that engine is well worth it. I just googled California gasoline octane and just learnt that 91 octane appears to be the highest pump gas available at non-specialty sellers. Up here in BC, our Chevron stations sell 94 octane with no ethanol.
Have a look at their website (which appears overdue for an update):
http://www.jandssafeguard.com/safeguard.html
There is even a member here on the Samba who built his own custom WBX engine with high compression and a few other mods and was very happy once he installed the Safeguard system:
http://www.jandssafeguard.com/safeguard.html _________________ '86 Syncro Westy SVX |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5695 Location: Bemidji, MN
Posted: Tue Jul 08, 2025 7:07 pm Post subject: Re: Pinging Puzzle 2.3L Digifant |
back when dinosaurs roamed the earth and massive displacement, high compression engines were the top predator, water injection was popular to control pinging. ain't nothing wrong with the technology, not as fancy as knock control but somewhat cheaper and still allows more ignition advance. plus it keeps carbon at bay.
back in the day, i made a crude system with an atomizer nozzle in the air cleaner and a washer fluid pump with a reservoir. it worked. would blend in some isopropyl in winter to keep the water tank from freezing. lotsa makers of system back in the day, you'll have to shop around now. here's an article on it that covers the basics:
https://www.hotrod.com/features/water-injection-august-1980-982-1190-26-1 _________________ -dan
www.thefixitworkshop.com |
DigiMatrix Samba Member
Joined: April 20, 2010 Posts: 495 Location: Up North Canada
Posted: Tue Jul 08, 2025 11:40 pm Post subject: Re: Pinging Puzzle 2.3L Digifant |
Which ECU are you using? Are you using the stock chip? I have seen a higher displacement/compression engine go lean at high load. In order to maintain 14.7:1 AFR the long term adjustment winds up to keep the engine fueled. When the WOT enrichment cuts in, the long term correction is zeroed and the WOT enrichment is added. The problem is, the fuel added by the long term correction is greater than the WOT enrichment, so the net result is less fuel so the engine runs lean => pinging can occur. Do you have a wideband to monitor you AFR? If not, you should get one. _________________ _________________
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17144 Location: Brookeville, MD
GoEverywhere Samba Member
Joined: December 13, 2020 Posts: 896 Location: Portland, OR
Posted: Wed Jul 09, 2025 8:10 am Post subject: Re: Pinging Puzzle 2.3L Digifant |
dobryan wrote: |
You may want to contact Mansispeed about their EFI system. I bet they can set you up so that you'll have no issues.
https://www.mansispeed.com/
(I never want to rely on my ears to detect knocking. By the time it is pronounced enough so my ears could hear it the knock had been happening earlier too.) |
I'll second that. You're missing out on what you engine COULD be by running a stock EFI system that isn't gonna know what to do with the modifications you've done.
On any other vehicle those mods would be hand in hand with getting the ECU tuned to properly support them. Sadly the Digifant ECU isn't smart enough for tuning. |
4Gears4Tires Samba Member
Posted: Wed Jul 09, 2025 8:18 am Post subject: Re: Pinging Puzzle 2.3L Digifant |
I don't know if Megasquirt is legal in CA. So that may be a consideration.
Crazy that 91 is the top octane available, 93 would have been my first suggestion.
I would not keep running around with pinging. You will get small craters in the top of your pistons. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13478 Location: West Coast, USA
Posted: Wed Jul 09, 2025 8:40 am Post subject: Re: Pinging Puzzle 2.3L Digifant |
4Gears4Tires wrote: |
I would not keep running around with pinging. You will get small craters in the top of your pistons. |
Megasquirt (and Mansi) are not CA legal. Only GoWesty has done the mountain of paperwork required to pass in CA. Of course, if you get a new kid or muscle car guy running your smog tests, they could gloss right over it.
91 AKI is the highest available octane at sea level in cities. Go up in elevation or to more rural areas and you'll find a larger selection. (91 'Merican is the same as 93 RON, which most of the civilized world uses.)
If you can hear pinging, your engine has been feeling it much longer.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 750 Location: Lancaster PA
Posted: Wed Jul 09, 2025 10:41 am Post subject: Re: Pinging Puzzle 2.3L Digifant |
How did you add oil squirters? |
Posted: Wed Jul 09, 2025 11:00 am Post subject: Re: Pinging Puzzle 2.3L Digifant |
I had a couple more thoughts about that knocking 2.3. First, as Dan Houg stated above, water injection is one possible solution and will not require you to reduce spark advance, either at the distributor (base timing) or with the J&S Safeguard system (dynamic spark retard).
But the other thought is that you might have a faulty crankcase ventilation unit. The diaphrgms all fail eventually. Oil fumes in the intake tract can cause knock. I was surprised that your knock was also occurring at relatively higher (say, 4,000) rpm. That suggested to me to look at oil fumes as a possible contributor. Disconnecting the breather hose connected to the intake manifold as an experiment might help determine whether this is contributing. _________________ '86 Syncro Westy SVX |
