1972 Type 4 distributor drive gear installation
Aaron Cox CT
Aaron Cox CT is offline
PostPosted: Fri Jul 11, 2025 10:14 am    Post subject: 1972 Type 4 distributor drive gear installation Reply with quote
Good afternoon all!
I am finishing up reassemble on the 1972 type 4 engine for my bus.
I have the bently manual and have also searched the sight and i think I have confused myself even more.
The engine is at #1TDC.
The distributor gear's "groove" that the distributor engages isnt centered. Looking in the bently manual i dont see any indication of which way the wider half circle should be...
Also looking at the bently manual the photos seem different then how ratwells post shows installing the gear. (Im guessing its just the perspective of the photos)
Which way should it be installed?
Or
Or neither?
As always thanks so much for all your help!
Aaron
Aaron Cox CT
PostPosted: Fri Jul 11, 2025 10:55 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Hmmmm So after looking at my distributor im thinking that this may be the correct orientation, the "little c" towards the flywheel?
I am running a vacuum assist distributor.
kreemoweet
kreemoweet is offline
PostPosted: Fri Jul 11, 2025 11:30 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Bentley Manual, Engine&Clutch section, page 24, fig. 8-2.
'67 bug: seized by the authorities
Aaron Cox CT
PostPosted: Fri Jul 11, 2025 11:40 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
But I cant figure out which way that photo is showing the off-center slot.
Does the bigger half go towards the flywheel or the fan?
lil-jinx
lil-jinx is offline
PostPosted: Fri Jul 11, 2025 11:48 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
picture #2 looks correct ,the grove ,should go roughly from 11 o'clock to 5 o'clock ,
1968 Dune Buggy sold dec 2024
1974 parts bus
Aaron Cox CT
PostPosted: Fri Jul 11, 2025 11:59 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Ahhhh...that drawing really helped! THANK YOU!
And what manual is that!! Thats fantastic!!
This forum is the absolute best!
lil-jinx
lil-jinx is offline
PostPosted: Fri Jul 11, 2025 12:01 pm    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
tom wilson ,how to rebuild your vw air cooler engine.
1974 parts bus
virusdoc
virusdoc is offline
PostPosted: Fri Jul 11, 2025 12:19 pm    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Be sure the washers that go underneath that pinion drive are still in place. Ideally this installation is done with the case open (and then a distributor installed to keep it in place) so you can ensure they don't fall down into the case.
1976 Convertible Super Beetle, "June Bug".
Self-rebuilt 1904
1976 Campmobile 2.0L FI, "Kermit"
Willin
Willin is offline
You will notice the shaft turns a little as it drops down in.
Allow for that. The picture in the book shows installed position.
Make sure the washer/spacer doesn't fall off the bottom of the shaft. Use a blob of heavy grease to "glue" it to the shaft.
73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit".
Aaron Cox CT
PostPosted: Fri Jul 11, 2025 12:49 pm    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Thanks for all the tips! Here goes nothin'
I'll let you know how it goes!
A.
Aaron Cox CT
PostPosted: Fri Jul 11, 2025 12:58 pm    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Whooo Hooo...I think it went as smooth as butter!
One more puzzle piece down!
Thanks all!
Wildthings
Wildthings is offline
PostPosted: Sun Jul 13, 2025 11:53 am    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Thanks all!
Hope you had the crankshaft turned to the correct TDC. If you used the incorrect one your engine will not start and run, but you can correct matters by moving the wires 180° around the cap.
germansupplyscott
germansupplyscott is offline
PostPosted: Sun Jul 13, 2025 4:24 pm    Post subject: Re: 1972 Type 4 distributor drive gear installation Reply with quote
Type 4 engine has only 1 special washer. Type 1 has multiple washers.
SL
