Intake Port Volume vs Displacement vs RPM
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Mon Jul 14, 2025 7:00 am    Post subject: Intake Port Volume vs Displacement vs RPM Reply with quote
Hoping some of you more experienced cylinder head guys can provide some insight to the subject topic.
Understanding that there is a relationship between intake port volume vs engine displacement and desired/intended rpm range, are there any calculations or rules of thumb that help figure out the "ideal" scenario?
For example:
-What intake port volume to shoot for on a particular combo, given the displacement and intended rpm range?
- Or coming from the other side, given a displacement and intake port volume, what sort of working RPM range could be expected?
(of course realizing that camshaft selection plays into these as well)
To throw in another wildcard, how does this relationship change with forced induction engines (or does it)?
I've dug through quite a few old threads and gained a lot of insight from folks like Brian_e, Alstrup, et. al, but was hoping to have a more detailed/specific discussion on this particular relationship of factors. Most of the threads I found had a comment or two in relation to a specific engine combo that was being discussed, but I didn't find anything that really dove into the subject more generally and how to apply it to other combos.
And for some case study: Laughing
There is quite a bit of interesting insight to be gained from several of the combos posted on CB's website (see link below).
https://www.cbperformance.com/category-s/352.htm
There are a lot of combos on that page using the 044 Panchito heads, which are relatively "small" heads that have a pretty low intake port volume compared to most all of their other CNC heads. CB/Pat managed (IMO) some impressive numbers from these small heads on relatively big CC engines (like 2276+). This was on both NA and turbo combos. However looking more closely, all of those big CC/Panchito combos used quite a bit more camshaft than the "normal" recommendations people tend to toss around for cam sizing. In short, a lot of the cams used are generally more considered drag racing type cams versus typical street cams, but the resulting power at RPM of these combos yielded more street oriented manners (i.e. peaks below 6k rpm). This presumably is directly related to the small port volumes of the 044 Panchito's, and needing more camshaft to adequately feed these bigger displacement engines, versus a more traditional combo.
If the above is true, how does that practically change if you swapped from the Panchitos to something like the wedgeport or miniwedge (with 10cc+ more port volume)? Presumably the cam could be pulled back some while still maintaining same/similar performance. But what else changes? I understand the concept that lower port volume = higher air speed = more torque (at least generally speaking). But what are the limits? Is there a particular advantage or disadvantage of either particular approach?
There is a lot in this line of questioning I know, but I'm hoping to stimulate some good discussion here, and hopefully continue to expand my deeper understanding of engine building. Thanks in advance!
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
Alexander_Monday
Alexander_Monday is offline
PostPosted: Mon Jul 14, 2025 9:54 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Black magic, but from what I have gathered it is more to do with the minimal cross-sectional area in the port compared to valve size and where the minimal cross-sectional area is along with port shape creating turbulence and how close to the wall the flow is (size of the boundary layer).
All that affects flow velocity which you do not want to go sonic but also don't want it too slow.
I would love to have an explanation that us lay people can follow.
I try to take in what I can from Darrin Morgan, but he mainly talks about bleeding edge race engines.
Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
andk5591 wrote:
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell.
Brian_e Premium Member
Brian_e is offline
PostPosted: Mon Jul 14, 2025 9:59 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Fantastic and very difficult topic.
There are formula to figure out most everything in an engine for sizing. The problem is lots of it is based on an ideal perfectly round, and perfectly straight piece of pipe for a port. We all know that is never the case.
As for figuring out the ideal port volume, here is how it "should" be done in an ideal world.
Use upper RPM and displacement to figure out the size of the minimal cross sectional area in the port.
An "ideal" port taper is around 7deg. according to different books, the Superflow manual, etc. Given the length of the port, the new MCSA at one end, and a 7deg taper, you can then figure out the volume of the port. This will get you the smallest "correct" port, with a minimal volume to keep the air in the port accelerating, but not choke.
You can also use the new MCSA to determine the ideal valve size. Lots of factors, but I prefer a 88% Valve to seat diameter ratio. This keeps the seat angles good, and makes for a really good venturi effect at the seat. Some heads can use a 90-92%, but they are usually very high RPM, and they need 50+ deg seats. Supposedly the 85-88% is the range for street engines, and it makes sense.
I have found the best thing to do is get a copy of the Pipemax software. It will do most all of the calcs for you, and if you start playing with it a bunch you can start to see what its doing. It will also calculate "theoretical" airspeed in the port which is also important to look at.
The Wallace calculators are also free, and they can offer a bit of insight.
As for the Panchito's on big engines, I have found they will do pretty much what Pipemax says they will for upper rpm limits, given the typical cams I am using. I am pretty skeptical of CB's dyno and flow bench numbers, but I do think using an otherwise BIG cam for the combo will help overcome the small port volume. Hanging the valve way open with a bunch of lift, and for a long duration is a sure fire way to help pack more air into the cylinders. As long as they don't hit sonic choke, it might just work.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
Brian_e is offline
PostPosted: Mon Jul 14, 2025 10:15 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
This is very true, and I also dig for anything Darrin Morgan has written. I don't get time to watch Youtube much, but I did stumble on his new series with DragBoss Garage. He is doing multiple in-depth videos on different parts of the ports, and he is keeping it more basic for the street guys rather than Pro-mod V8, 9500rpm 5000hp specific. Its a subscription thing, but if you could pay the fee, and then watch them all one after the other, it would be a huge amount of info for a small price.
Brian
-Modok
Alexander_Monday
PostPosted: Mon Jul 14, 2025 10:52 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Brian
I have watched a few of the free DragBoss Garage videos with Darrin, as well as any others I could find with him.
What do you think of the ongoing induction series by Bain Racing?
One thing that I have not gotten a clear answer to is whether secondary plenums when you have a long forced induction system are worth the effort.
My supercharger dumps up into a water to air intercoooler then into a plenum.
There are 4 1-1/2' ID bell mouth outlets with 1-1/2' ID tubing going 36" to the valves.
Those are very long and low resonate frequency intake runners and I am limited on room to add secondary plenums due to my custom dual fans.
Brian_e is offline
PostPosted: Mon Jul 14, 2025 1:24 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
I have not watched any of the other videos. I also don't work with anything forced induction, so I don't have any real world info on your setup. Dumping into a second plenum doesn't sound ideal from an airflow standpoint. Lots of changing airspeed, and turning corners, but you have pressure on your system, so that might be out the window?
Brian
-Modok
Wreck
Wreck is offline
PostPosted: Mon Jul 14, 2025 2:54 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
David Vizard "How to port and flow test cylinder heads" is worth buying , he mainly has examples of V8 stuff but it is relevant . He also has a YT channel but tends to waffle on a little too much for my patience level !
I use the above book and Pipemax . Also this online calculator .https://hotwater.gregraven.online/calculators/valve-sizing
Brian_e is offline
PostPosted: Mon Jul 14, 2025 3:16 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
These two books are also very good.
https://www.amazon.com/Practical-Engine-Airflow-Pe...amp;sr=1-1
https://www.amazon.com/Engine-Airflow-HP1537-Pract...amp;sr=1-2
Along with a copy of the Superflow flowbench owners manual if you can find one.
Brian
-Modok
Vee Dub Nut
PostPosted: Mon Jul 14, 2025 3:35 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Black magic
Laughing
I agree, it's a pretty interesting topic.
I knew there probably wasn't a quick or easy answer, but I'm trying to dig a little deeper to further my understanding on engine building beyond the surface level.
@everyone
Thank you all for the comments and suggestions where to look to learn more! The Pipeworks software looks like it would be a fun tool, and the book recommendations and various peoples to look up on YT are all good resources. A lot more info for me to go chew on.
67 Beetle (TBD)
Dusty1
Dusty1 is offline
PostPosted: Tue Jul 15, 2025 6:06 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Except on the old Champ car Offenhauser engines. Huge oval ports because oval ports are round ports, connected when you have four valves per cylinder. You can almost reach in the intake port and poke a finger out the exhaust port with the valves removed.
Blows my mind the old Offy motors are nearly a 100 year old design.
Won't be long until our VWs are a 100 year old design. Rolling Eyes
Zed999
Zed999 is offline
PostPosted: Tue Jul 15, 2025 6:23 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Type-4 heads get fairly close? Much straighter than T1 ports.
Brian_e is offline
PostPosted: Tue Jul 15, 2025 8:18 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Yes, T4 ports are much much closer to ideal. Near perfectly round, and almost straight. That is also why a 42mm valve in a T4 head will flow WAY better than a 42mm valve in T1 head. T4 heads have the opposite problem on the exhaust though. Tiny cross section, super hard bend, and not much material to work with.
Brian
-Modok
Brian_e is offline
PostPosted: Tue Jul 15, 2025 8:23 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
That's what happens when you design a clean slate race engine with no rules, and then you build the car around the engine. They didn't have to fit it under a hood, make it idle at 20deg F. or compromise performance because they needed to manufacture and build 30million of them.
Brian
-Modok
chrisflstf
chrisflstf is offline
PostPosted: Tue Jul 15, 2025 11:03 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
The link Wreck provided is interesting as it shows higher rpm, more so than displacment , above 5k, mostly, is where larger valves become necessary. But from what ive learned, the port needs to be matched to the valve size for optimum performance, rather than just putting bigger valves in a small sized valve and port head
Wreck
Wreck is offline
PostPosted: Tue Jul 15, 2025 2:52 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
That calculator is for valve size at peak horse power(not peak revs) to prevent choke . You then work out the correct port size to suit the valve ,like Brian mentioned . Then only remove material where it makes a difference.
I have used a simple set up with a vacuum cleaner and a manometer ( https://www.musclecardiy.com/cylinder-heads/build-...ds-part-3/ )
Then used plasticine /playdough to fill small areas , a flat bladed screw driver also works instead of flow balls . if you put something in an area of the port and the flow doesn't change , don't remove material from that area .
It is cheap to set up and fun to play with and makes you understand why heads are ported in the areas they are by the experts . Also why some home port jobs will make the car slower !
I've also used a glass cylinder and cotton thread to see the flow into the combustion chamber (as important as the port)
Alexander_Monday
PostPosted: Tue Jul 15, 2025 3:26 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
Interesting read.
I built one a long time ago that allowed me to wreck a few 041 heads to get to the heads I used at the time.
I used the old GM frequency MAF from a Camaro and a frequency counter between a big ball valve and the bench and a DIY water manometer.
Had a vacuum from a wood chip separator that got replaced with a newer unit at a wood working shop.
Used a friend of mines calibration plates from his shop.
Worked a treat until the vacuum finally gave up and was too expensive to replace.
My buddy put one of my heads on his flow bench and got +-10% of what I did.
modok
modok is offline
PostPosted: Tue Jul 15, 2025 10:24 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
That supercharger really throws a wrench into this question
best for you
just make the whole path from central plenum to the "intake runner length" large, the whole way.
You could just have a connection between your pairs of tubular runners on either side, the connection located at the correct distance from the head to make the runner the right length 16 or 20" or whatever you think, and then from that "connection" to the head is the actual runner length, and step up the size a bit if practical from the main plenum to this connection, so the actual path from the plenum to the runners is 2.5 or 3x larger area.
Why still have two tubes? well........cause it looks kewl?
Won't work any better than having huge 3 inch or 4 inch tubes leading to your runners on either side, but IMo would be easier and fit better and look more elegant than one huge tube or trying to make an oval tube.
Sorry to jump the the conclusion but we have to get that solved before we can even get into the quesion in the first post.......becase the intake harmonic chosen actually changes the ideal port and runner size.
A longer harmonic length, we should all agree, takes longer to accelerate and decelerate, therefore with a longer runner length the bulk of flow has to happen in a smaller window of time, meaning the longer the runner the larger the port and runner needs to be. Usually people design engines from the inside out so they figure out the right harmonic length for the head used.......... trying to figure out the right head for an overly long runner length.......your going to find out it's larger than would make any sense for sure.
ALTHOUGH, the rules of runner taper are a lot wilder than any angle.
It can work to have the last 1/4 or 1/3 (can't remember which) quite a lot smaller and that can work well, provided that small section is not jammed into a bend. and that could work for you, since it's port injected, it would mean your runner size would be larger than usual really. Most of the ram action happens in the lower third of the intake length, so runners can be straight, or tapered, or stepped, with similar overall result, the best being whichever fits best.
That's one subject where the lightbulb only lit up recently.....after watching
Darren Morgan and looking at a sbc again for the millionth time I realized that it kinda.............just, its all true, like, the pinch point. Some hate it, some love it, but the main thing is that it just fits, where it is -works-. It's gotta be in a straight line downstream and in the lower 1/3 of the intake length, and bend before the pinch point, not during or after, then it's a feature not a bug. But if you make it a problem, then it's a problem
Alexander_Monday
PostPosted: Wed Jul 16, 2025 7:35 am    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
I designed the dual fan housings about 20 years ago now in the old Fluent CFD and I must say that all 4 CHT under the plugs and all 4 EGT are excellent, but working the intakes around them makes for a packaging problem.
I have done a lot of analyzing of the pressures in the intake system.
The harmonics are strong enough at low rpm that they create a problem for idle with a negative zone that makes it very hard to get idle much below 1400 with the FK10/87 cam I had in it.
I had to go to fully sequential injection and get the injection timing just right.
Here is a composite gif of the pressure differential between #3 runner just above the head and the plenum in red and the 36-1 crank pickup in blue swept from 1400 to 7200 to 1400 rpm with the vertical center artificially held at compression TDC.
As you can see, at high rpm the pressure differential is positive where it needs to be and drops off after the intake valve opens.
But at low rpm that nasty negative pressure differential is present just before the intake stroke.
Remember this is differential, not absolute pressure.
sidemarkers
sidemarkers is offline
PostPosted: Thu Jul 17, 2025 4:18 pm    Post subject: Re: Intake Port Volume vs Displacement vs RPM Reply with quote
In the 90's a friend made an efi manifold for his turbo sand rail. The cylindrical plenum with throttle body hovered over the fan shroud and each of the 4 long runners spidered along the shroud and mounted to the heads with flanges.
Idled well and pulled like a freight train up to about 5000 rpm then it fell on it's face. Think it has to do with the length of the pressure waves and your desired rpm range.
