gefne99 Samba Member
Posted: Mon Jul 14, 2025 12:33 pm Post subject: Sept 56 oval heater channels |
I have an oval window with a late September build date. She is a 57 model year. The driver side heater outlet is forward and the passenger side is back. Do we know what serial number they changed over at? The heater knob is between the seats.
Thanks for any help |
lardawge Samba Member
Joined: October 05, 2020 Posts: 399 Location: California
Posted: Mon Jul 14, 2025 1:41 pm Post subject: Re: Sept 56 oval heater channels |
They were moved back in December 56 starting with vin 1385974.
Sounds like someone changed the passenger side channel with a later model. _________________ 11/2/54 L227 Strato Silver Ragtop - Build Thread
1/7/55 L275 Light Beige - Build Thread |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4776 Location: St Charles, MO
Posted: Wed Jul 16, 2025 8:41 am Post subject: Re: Sept 56 oval heater channels |
When you refer to driver side "heater outlet" are you talking about the forward-most round outlet that hot air from the heater channel ducting underneath the cylinders and pushrods would force forward into the actual heater boxes when the flap doors are closed to then head into the cars interior to warm you up? I have a Dec of 1956 produced Kabrio that is about 400 chassis numbers earlier than the chassis number mentioned as when the change happened. I'm not clear on what change you are discussing. Any photos showing what you are asking about? Thanks!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Käfer2 Samba Member
Joined: December 30, 2019 Posts: 72 Location: Germany
Posted: Wed Jul 16, 2025 12:41 pm Post subject: Re: Sept 56 oval heater channels |
lardawge wrote: |
Sounds like someone changed the passenger side channel with a later model. |
Exactly, gefne99's passenger side should look like my late oval channel front heat outlets (1366xxx = through vin 1385974), before they moved back.
