The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 846 Location: Arizona
Posted: Thu Jul 17, 2025 4:24 pm Post subject: Plastic screw caps on 2002 Weekender … how to remove? |
I have spent quite a bit of time on the internet and the Samba the past couple of days researching how to install the new Boss 9” screen stereo with backup camera, and now pretty clear on how to install thanks to those here that have done it already! Except…. In order to remove the upper plastic trim panels, you’ve got to remove these plastic caps…. and nowhere does anyone reference how to remove them without damaging! I know a small screwdriver would do the job, but would no doubt damage them. Anyone have done this, and has a way to remove without damaging? Thanks , Bob
_________________ 1964 vert "Patience"
2002 Eurovan MV “Winnie”
Sold the 63 vert “ Lizzie”
Sold the 76 Westfalia “ Winnie” |
bigfoot_ev Samba Member
Posted: Thu Jul 17, 2025 8:45 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
I have not found the magic solution. But, I have removed those little caps so frequently that I definitely have ruined some. Especially the ones holding on the rear cross piece. I have used a small screwdriver, a thin plastic interior trim tool, and even a utility knife. Whatever you use just be gentle and patient and you should get some repeated use out of the covers.
The rear ones were so far gone I gave up and replaced them with hinged screw covers. Something like this: https://www.amazon.com/INCREWAY-Covers-100pcs-Plastic-Storage/dp/B0CLZZB3FX/ref=sr_1_6
I also use these on the sliding door for a couple of screws. _________________ 2003 Westfalia Weekender, AXK, 01P |
Posted: Thu Jul 17, 2025 9:22 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
Bigfoot, thank you! Any idea what size ? I am debating whether to try removing them, or going for installing the wires in the small crevices between the floor and the wall panels , then removing the B panel, removing the panel above the door and A panel and then behind the dash and to the radio. Going to install the radio first and then decide about the route to the backup camera. I will still buy the caps! ( So I have an option). But Either way I will document the install for others. Thanks again, Bob _________________ 1964 vert "Patience"
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11079 Location: Oregon
Posted: Thu Jul 17, 2025 9:32 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
I'd use a small pick tool like a dental pick to try to get the caps off. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Thu Jul 17, 2025 9:55 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
The Volkswagen Ranch wrote: |
Bigfoot, thank you! Any idea what size ? I am debating whether to try removing them, or going for installing the wires in the small crevices between the floor and the wall panels , then removing the B panel, removing the panel above the door and A panel and then behind the dash and to the radio. Going to install the radio first and then decide about the route to the backup camera. I will still buy the caps! ( So I have an option). But Either way I will document the install for others. Thanks again, Bob |
I believe the screws are M4. When I installed my backup camera I went up the A pillar and across the top, like you first thought. If you're careful removing the caps you won't have any issue reusing them. Try one, if you bugger it up just turn it so it's not so visible.
67rustavenger wrote: |
I'd use a small pick tool like a dental pick to try to get the caps off. |
Oh yeah, I tried that too. Yep, that's another option. _________________ 2003 Westfalia Weekender, AXK, 01P |
Posted: Sat Aug 02, 2025 5:42 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
Well, after a VERY LONG whole day, I know when I’m “beat.” Trying to remove the plastic panel on the A pillar…. And almost cracking it…. I am not going to risk cracking the “ brittle with age” plastic trim panels on the interior to run the wiring for the rear camera. I also tried going along the outline of the plastic trim in the floor, which was MUCH more cooperative, but alas, that way the wire for the connection to the camera is about 3’ too short. I can get longer RCA cables, but they won’t work with the Boss supplied camera, as not a typical RCA cable connector. I will get another camera…. and need recommendations! So…. I think I read somewhere that someone had gone underneath with wiring….if you have, please let me know the entrance and exit paths that you took! Bob _________________ 1964 vert "Patience"
germanoldschool Samba Member
Posted: Yesterday 12:14 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
Maybe one of those wireless transmitters would work for you. They come with yellow video cinch cable signal input. I was toying with one of those to connect a universal camera to my original vw navigation screen. I did install a universal wireless backup camera with separate screen in a Metris and it works very well. |
Posted: Yesterday 1:50 pm Post subject: Re: Plastic screw caps on 2002 Weekender … how to remove? |
Well, did MORE reading and research. I will update after I receive the new hardware I just ordered. Thanks to all that are “ coaching “ me. As you all have cautioned….. this is a “”PITA.” Bob _________________ 1964 vert "Patience"
